I did some calculations:
An USB with SLC NAND Flash can do maximum 100.000 write cycles. On an USB with 8GB with 10 MB/s write speed will that be:
(My math skills or not very good, I know for sure you can do this on an easier way)
((8192 / 10 )) * 100.000) / (365.242 * 3600 * 24) = 2.595945012206012 years.
So, when you write on your USB with 10 MB/s for 2,6 years it will be broken. Its true that it will be broken earlier. but when you have a good controller it will last very long. So yes, an USB with SLC NAND flash is a good option.
You also have SD cards on SLC NAND flash, but I don't know the technical details about the controller in the Raspberry pi, besides that. In my country an USB stick is cheaper then a SD card. So I bought a small SD card and an USB stick.
There is one downside, an USB stick needs power. USB can max consume 0.5 ampere. Model A of the PI has a limited USB power output, and not every power supply’s can handle that much amperes. So you need to check this before you buy an USB stuck for your PI.
Source:
“SLC NAND flash is typically rated at about 100k cycles (Samsung OneNAND KFW4G16Q2M) ” on the page:
http://en.wikipedia.org/wiki/Flash_memory
