I've bought a month ago a new Raspberry Zero to try this little toy. I'm already playing with a Raspberry and linux OS in general but this time i'm very close to give up. The problem is that this Raspy won't display boot messages, this is what i've tried:
- 16gb with NOOBS v1.5.0 image (boots on pi2)
- Same 16gb card with raspian jessie image (2015-11-21 and also this boots on pi2)
- Old 8gb SD from pi2 with jessie raspian ( this give 7 green led flashes )
- .txt file to force HDMI hotswap and other commands video-related (copied below)
- HDMI to DVI cable
- HDMI to HDMI cable (actually I've tried 2 of them)
- Different monitor or TV
- With or without micro USB to female Usb adapter to connect a keyboard
here is my config.txt:
# For more options and information see
# http://www.raspberrypi.org/documentation/configuration/config-txt.md
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# NOOBS Auto-generated Settings:
config_hdmi_boost=4
overscan_left=24
overscan_right=24
overscan_top=16
overscan_bottom=16
disable_overscan=0
In general I can see the green led acting as a status led when is loading but no HDMI output is showing on monitor.
I hope to have been detailed as possible, unfortunately with mi first RPi B and the RPi 2 i've never issued this kind of problem.
Here is the video of the problem, for the full time the monitor still black with no signal alert: Video link
Thanks in advance!
UPDATE 1
I tried to connect the UART to my USB to ttl converter during boot and now I can see all mesages and login prompt. Seems working ok but still no HDMI output. I alredy tried to tweak the output with all available mode on tvservice command but both my monitor and my tv shows no signal.
hdmi_force_hotplug=1toconfig.txt? Have you triedhdmi_safe=1(see here). Beware that if you seriously want help, you should make a serious effort to detail exactly what you've done, exactly what's happened, etc. – goldilocks Jan 26 '16 at 20:05config.txtfile to tinker with HDMI. – Phil B. Jan 26 '16 at 20:13
