I was lucky enough to get a Raspberry Pi under the tree this year and I've had a bit of fun playing with Node.js on the device. However, Node.js is much more interesting when you can pull down packages and plug them into your applications - and this is where I am having some trouble.
If I attempt to install NPM along with Node.js with the following command:
sudo apt-get install nodejs npm
I get the following error:
pi@raspberrypi ~ $ sudo apt-get install nodejs npm
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
nodejs : Breaks: npm (< 1.1.4~dfsg-2~) but 1.1.4~dfsg-1 is to be installed
npm : Depends: node-semver but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
I'm pretty new to how package management works with Debian-based Linux operating systems and don't know much at all about how the node.js community has structured their specific packages. It is worth noting that installing node.js by itself works just fine, and if I try to install NPM just by itself this is what I get.
pi@raspberrypi ~ $ sudo apt-get install npm
npm : Depends: nodejs but it is not going to be installed
Depends: nodejs-dev but it is not going to be installed
Depends: node-request but it is not going to be installed
Depends: node-mkdirp but it is not going to be installed
Depends: node-minimatch but it is not going to be installed
Depends: node-ini but it is not going to be installed
Depends: node-graceful-fs but it is not going to be installed
Depends: node-abbrev but it is not going to be installed
Depends: node-nopt but it is not going to be installed
Depends: node-fstream but it is not going to be installed
Depends: node-rimraf but it is not going to be installed
Depends: node-tar but it is not going to be installed
Depends: node-which but it is not going to be installed
I'm not sure, but my gut is telling me that it is something to do with the node-semver package. If I install the nodejs package by itself and then attempt to install node-semver this is the output that I get.
pi@raspberrypi ~ $ sudo apt-get install node-semver
node-semver : Depends: nodejs but it is not going to be installed
Any pointers?
/usr/local/binwould be slightly more appropriate for local-admin-managed symbolic links to a local-admin-managed filedump in/opt– JamesTheAwesomeDude Jun 16 '18 at 12:53
