#include <cstdint>
#include <fstream>
#include <iostream>
#include <stdexcept>
#include <streambuf>
#include <sstream>
#include <string>
#include <fcntl.h>
#include <sys/ioctl.h>
#include <unistd.h>
// Header: /opt/vc/include/bcm_host.h
// Library: /opt/vc/lib/libbcm_host.so
#include <bcm_host.h>
std::string ReadCPUInfo()
std::ifstream fileStream("/proc/cpuinfo");
if(!fileStream)
throw std::runtime_error("Could not open: `/proc/cpuinfo`.");
std::string cpuinfo((std::istreambuf_iterator<char>(fileStream)), std::istreambuf_iterator<char>());
fileStream.close();
return cpuinfo;
std::string ReadSysBoardModel()
std::ifstream fileStream("/sys/firmware/devicetree/base/model");
if(!fileStream)
throw std::runtime_error("Could not open: `/sys/firmware/devicetree/base/model`.");
std::string model((std::istreambuf_iterator<char>(fileStream)), std::istreambuf_iterator<char>());
fileStream.close();
return model;
std::string ReadSysBoardSerial()
std::ifstream fileStream("/sys/firmware/devicetree/base/serial-number");
if(!fileStream)
throw std::runtime_error("Could not open: `/sys/firmware/devicetree/base/serial-number`.");
std::string serial((std::istreambuf_iterator<char>(fileStream)), std::istreambuf_iterator<char>());
fileStream.close();
return serial;
std::string ReadSysMACAddress()
std::ifstream fileStream("/sys/class/net/eth0/address");
if(!fileStream)
throw std::runtime_error("Could not open: `/sys/class/net/eth0/address`.");
std::string address((std::istreambuf_iterator<char>(fileStream)), std::istreambuf_iterator<char>());
fileStream.close();
return address;
std::string ReadMailboxBoardModel()
int fd = open("/dev/vcio", 0);
if (fd == -1)
throw std::runtime_error("Could not open: `/dev/vcio`.");
uint32_t property[32] =
0x0000001C, // Buffer size in bytes (including the header values, the end tag and padding): 7 * 4 = 28 = 0x1C.
0x00000000, // Request code: 0x00000000 = process request.
0x00010001, // Tag identifier: Get board model.
0x00000004, // Value buffer size in bytes: 1 * 4 = 4 = 0x4.
0x00000000, // Request code: b31 clear: request, b30-b0: reserved.
0x00000000, // Value buffer.
0x00000000 // End tag: 0x0
const unsigned long MAJOR_NUM = 100;
if (ioctl(fd, _IOWR(MAJOR_NUM, 0, char*), property) < 0)
close(fd);
throw std::runtime_error("`ioctl` failed.");
if (property[1] != 0x80000000)
close(fd);
throw std::runtime_error("Request failed.");
close(fd);
std::stringstream stream;
stream << std::hex << property[5];
std::string result = stream.str();
return result;
std::string ReadMailboxBoardRevision()
if (fd == -1)
0x00010002, // Tag identifier: Get board revision.
close(fd);
close(fd);
close(fd);
return result;
std::string ReadMailboxBoardSerial()
if (fd == -1)
0x00000020, // Buffer size in bytes (including the header values, the end tag and padding): 8 * 4 = 32 = 0x20.
0x00010004, // Tag identifier: Get board serial.
0x00000008, // Value buffer size in bytes: 2 * 4 = 8 = 0x8.
close(fd);
close(fd);
close(fd);
stream << std::hex << property[5]; // property[6] ignored.
return result;
std::string ReadMailboxMACAddress()
if (fd == -1)
0x00010003, // Tag identifier: Get board MAC address.
close(fd);
close(fd);
close(fd);
unsigned char* ptr = reinterpret_cast<unsigned char*>(&property[5]);
stream
<< std::hex
<< static_cast<int>(ptr[0]) << ":"
<< static_cast<int>(ptr[1]) << ":"
<< static_cast<int>(ptr[2]) << ":"
<< static_cast<int>(ptr[3]) << ":"
<< static_cast<int>(ptr[4]) << ":"
<< static_cast<int>(ptr[5]);
return result;
std::string ReadOTPDump()
bcm_host_init();
char buffer[1024] = { 0 };
if (vc_gencmd(buffer, sizeof(buffer), "otp_dump") != 0)
bcm_host_deinit();
throw std::runtime_error("Could not execute `otp_dump` command.");
bcm_host_deinit();
std::string otpDump = buffer;
return otpDump;
int main()
std::cout << "-------------------- CPU Info: $ cat /proc/cpuinfo --------------------" << std::endl;
std::cout << ReadCPUInfo() << std::endl;
std::cout << "-------------------- Board Model: $ cat /sys/firmware/devicetree/base/model --------------------" << std::endl;
std::cout << ReadSysBoardModel() << std::endl;
std::cout << "-------------------- Board Serial: $ cat /sys/firmware/devicetree/base/serial-number --------------------" << std::endl;
std::cout << ReadSysBoardSerial() << std::endl;
std::cout << "-------------------- MAC Address: $ cat /sys/class/net/eth0/address --------------------" << std::endl;
std::cout << ReadSysMACAddress() << std::endl;
std::cout << "-------------------- Board Model: $ /opt/vc/bin/vcmailbox 0x10001 0x4 0x0 0x0 --------------------" << std::endl;
std::cout << ReadMailboxBoardModel() << std::endl;
std::cout << "-------------------- Board Revision: $ /opt/vc/bin/vcmailbox 0x10002 0x4 0x0 0x0 --------------------" << std::endl;
std::cout << ReadMailboxBoardRevision() << std::endl;
std::cout << "-------------------- Board Serial: $ /opt/vc/bin/vcmailbox 0x10004 0x8 0x0 0x0 0x0 --------------------" << std::endl;
std::cout << ReadMailboxBoardSerial() << std::endl;
std::cout << "-------------------- MAC Address: $ /opt/vc/bin/vcmailbox 0x10003 0x8 0x0 0x0 0x0 --------------------" << std::endl;
std::cout << ReadMailboxMACAddress() << std::endl;
std::cout << "-------------------- OTP: vcgencmd otp_dump --------------------" << std::endl;
std::cout << ReadOTPDump() << std::endl;
return 0;
