A more generic answer for people sent here by Google
My issue was with the package libsoxr0:armhf but Google found this to be the most relevant question.
Why you should NOT downvote this answer
I hate that I have to do this, but I've been using SO/SE for over a decade and I know how negative people can be.
I teach children and adults to hack RaspberryPi, Arduino, ESP8266, etc. at multiple Maker Spaces. I'm putting this answer here for them and not for the OP that created this question in 2012
The problem
In my case I searched for my exact error message:
files list file for package 'libsoxr0:armhf' is missing final newline
The answers here would not have helped my if I would have done a blind copy/pasta, but luckily I have enough experience to cautiously use the info to resolve my issue. Read on to learn to the skills to do the same.
The solution
1st define variables so that future readers can copy/pasta
That future reader just might be yourself.
# Put the name of your package here
pkg='libsoxr0:armhf'
Inspect the file and compare it to something similar
This will show you the content of your file without corrupting (which would only be a temporary until you close and reopen or possibly correct it with tset or reset) your tty ([incorrectly] aka: terminal, shell, bash, etc.)
# To exit the command `less` hit "q"
less /var/lib/dpkg/info/$pkg.list
You'll probably see some non-ascii garbage in there. Compare that to anything else.
less /var/lib/dpkg/info/init.list
In mine I have... (that last line is not IN the file, it's part of the UI of the less command)
/usr
/usr/share
/usr/share/doc
/usr/share/doc/init
/usr/share/doc/init/changelog.gz
/usr/share/doc/init/copyright
/var/lib/dpkg/info/init.list (END)
Note: I chose init.list because it was the smallest file according to ls -lS /var/lib/dpkg/info/*.list, but it your original error had said for package 'init', you'd want to chose another file from the output of that ls command.
Eliminate the problem
Any time you read something on the internet that says "fix your problem by deleting this file/directory" you should instinctively translate that to "move it out of the way and take notes".
# start in your home directory
cd
create a directory to keep your stuff organized
directory="HACK $(date)"
mkdir "$directory"
cd "$directory"
remind yourself where you got this [possibly dumb] idea
url="https://raspberrypi.stackexchange.com/a/138679/8375"
echo "$url" >> FROM.url
finally do the only thing you REALLY needed to do if the instructions you were following were perfect
sudo mv /var/lib/dpkg/info/$pkg.list ./
sudo apt install $pkg --reinstall
compare the file you just moved the one that got recreated
write yourself a love letter
history >> HISTORY.txt
lay it on thick
echo "I think you are awesome." >> README.txt
echo "I know I don't say it as often as you deserve to hear it." >> README.txt
echo "☮️❤️☸️☯️" >> README.txt
Artifacts
Now that everything is working, I can remove the directory I created to clean up. Here is one last peek before it goes away...
pi@openmediavault:~/HACK Sun Aug 14 10:23:51 CDT 2022 $ ls -la
total 32
drwxr-xr-x 2 pi users 4096 Aug 14 11:02 .
drwxr-xr-x 9 pi users 4096 Aug 14 10:47 ..
-rw-r--r-- 1 pi users 128 Aug 14 11:02 FROM.url
-rw-r--r-- 1 pi users 12748 Aug 14 11:02 HISTORY.txt
-rw-r--r-- 1 pi users 124 Aug 14 11:02 README.txt
Oh, who am I kidding? I can't throw that away. I'm just going archive it over on my OpenMediaVault JBOD. Oh wait, it's already there.
