i'm rather new to Linux and all that, in fact the Raspberry Pi 3 i just got is the first Linux-only machine i ever had, running the latest version of Raspbian .. so here's my problem:
I'm trying to use the integrated wifi adapter to establish a connection to my network / the interhet.
I do see my network showing up and i can try to connect to it, but it keeps either doing nothing (if i use the GUI thingie in the top right corner of the screen [sorry, i'm sure it has a propper name but i couldnt see any]) or it sais that the authentication failed when i try it with wpa_gui
Now here are my specs, i hope i get everything in there that is needed:
ifconfig -a says:
eth0 Link encap:Ethernet HWaddr b8:27:eb:6e:78:19
inet addr:192.168.0.163 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: 2a02:810a:11c0:2c8c:dfe1:d49f:7f8c:a4a1/64 Scope:Global
inet6 addr: fe80::eac9:60d9:4260:247c/64 Scope:Link
RX packets:8277 errors:0 dropped:0 overruns:0 frame:0
TX packets:7779 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:6894047 (6.5 MiB) TX bytes:1298763 (1.2 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:136 errors:0 dropped:0 overruns:0 frame:0
TX packets:136 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:11472 (11.2 KiB) TX bytes:11472 (11.2 KiB)
wlan0 Link encap:Ethernet HWaddr b8:27:eb:3b:2d:4c
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:517 errors:0 dropped:517 overruns:0 frame:0
TX packets:30 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:165242 (161.3 KiB) TX bytes:5325 (5.2 KiB)'
my etc/network/interfaces file i modified quite a few times already, trying out several things, currently its looking like this:
auto wlan0
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
and the etc/wpa_supplicant/wpa_supplicant.conf has this here:
update_config=1
network={
ssid="MySSID"
psk="MyPsk"
proto=RSN
key_mgmt=WPA-PSK
pairwise=TKIP
auth_alg=OPEN
The network i am trying to connect to is WPA2 PSK encrypted with TKIP, my only guess here is that i have to make some settings either in Raspbian's wpa_supplicant.conf or in my router to let the two of them communicate with each other?
Or am i missing something totally obvious here?
I would also be grateful for hints on what tools i can use under Linux to figure this problem out and see where what goes wrong :)
Thanks a lot in advance and sorry if i messed up any english ;)
