So I just got a Raspberry Pi Zero and an SD card with NOOBS pre-installed. I placed the SD card onto the RPi as well as a keyboard and a power supply. I plugged the RPi onto two different monitors, however there was no video output (HDMI) on both. I tried cycling through pressing 1-4 on my keyboard, however nothing worked.
There is a constant green LED flashing, apparently this means there is some sort of error on boot up? I'm very new to all of this, what would you guys recommend that I do?
Greenonline
  • 2,740
  • 36
Shri
From what you've said, you seem to be plugging the HDMI cables last. You need to plug the HDMI cable in before you plug in the power cable usually - especially if you're starting up for the first time.
If your ACT led is flashing in a pattern, and not irradically, you should refer to my answer here. The easiest fix for basically all of the possible problems is to reformat your sd card.
Patrick Cook
  • 6,365
  • 37
  • 63
