I've found that many of the GPIO pins are not usable on a stock installation of Raspbian with gpio-admin.
For example, I wired up a relay to GPIO 21 only to find after some debugging that it didn't work as desired. Its neighbors GPIO 17 and GPIO 22 both work as expected. GPIO 21 is labeled as PCMD_OUT, so I'm guessing it's being used for another purpose.
So I'd like a few things explained in a straightforward way:
  1. Which pins are usable to read/write "out of the box?"
  2. Which pins can be used with some modifications (and how)?
  3. Which pins cannot be used at all?
notlesh
  • 233
At reset only pins GPIO 14 & 15 are assigned to the alternate function UART, these two can be switched back to GPIO to provide a total of 17 GPIO pins
Do you have a Rev2 board? See here
R-Pi PCB Revision 2 UPDATE: According to Eben at [1] the R-Pi Rev.2 board being rolled out starting in September 2012 adds 4 more GPIO on a new connector called P5, and changes some of the existing P1 GPIO pinouts. On Rev2, GPIO_GEN2 [BCM2835/GPIO27] is routed to P1 pin 13, and changes what was SCL0/SDA0 to SCL1/SDA1: SCL1 [BCM2835/GPIO3] is routed to P1 pin 5, SDA1 [BCM2835/GPIO2] is routed to P1 pin 3. Also the power and ground connections previously marked "Do Not Connect" on P1 will remain as connected, specifically: P1-04:+5V0, P1-09:GND, P1-14:GND, P1-17:+3V3, P1-20:GND, P1-25:GND. According to this comment [2] (and confirmed in this post [3]) the P1 pinout is not expected to change in future beyond the current Rev.2 layout.
In that case you should try GPIO 27 instead of GPIO 21
John La Rooy
  • 11,947
  • 47
  • 75
Here is the layout of the P1 connector:
P1-02  5V      5V
P1-04  5V      5V
P1-06  GND     GND
P1-08  GPIO14  GPIO14
P1-10  GPIO15  GPIO15
P1-12  GPIO18  GPIO18
P1-14  GND     GND
P1-16  GPIO23  GPIO23
P1-18  GPIO24  GPIO24
P1-20  GND     GND
P1-22  GPIO25  GPIO25
P1-24  GPIO8   GPIO8
P1-26  GPIO7   GPIO7
P1-01  3.3V    3.3V
P1-03  GPIO0   GPIO2
P1-05  GPIO1   GPIO3
P1-07  GPIO4   GPIO4
P1-09  GND     GND
P1-11  GPIO17  GPIO17
P1-13  GPIO21  GPIO27
P1-15  GPIO22  GPIO22
P1-17  3.3V    3.3V
P1-19  GPIO10  GPIO10
P1-21  GPIO9   GPIO9
P1-23  GPIO11  GPIO11
P1-25  GND
This table shows both the Rev1 and Rev2 layouts. As you can see, in Rev2, the bin between GPIO17 and GPIO22 is GPIO27 instead of GPIO21. This is probably the source of your problem.
Jerome
  • 131
