I've got a raspberrypi zero with this Ethernet Network Adapter. It works fine but the speeds are very slow. On my laptop I can test my ISP's connection at about 50Mbps (down) 30Mbps(up).
But running speedtest-cli on debian jessie I can only get 4Mbps(down) 3Mbps(up).
- Is there a way that I can improve this?
- Is it a problem with the Ethernet Adapter itself?
- Can I improve bandwidth with a WLAN usb Dongle?
here is the result of lsusb:
Bus 001 Device 002: ID 0fe6:9700 Kontron (Industrial Computer Source / ICS Advent) DM9601 Fast Ethernet Adapter
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
UPDATE: I've tried to power the pi with a nexus 5 charger and a ipad charger. Got the same (slow) results. I've plugged the Ethernet Network Adapter to my laptop running win 7. And got the very same (slow) results. So 2 different OS with same results? Poor hardware?
Current with WLAN:
With the Ethernet Network Adapter:
max_usb_current=1in /boot/config.txt and reboot device. This should increase power output over usb port to maximum. – Huczu Apr 26 '16 at 13:50
