45
Let's assume that I am dropped into a room with a Raspberry Pi running either Debian or Raspbian. How do I find out if it has hard float support or if it is just using soft float?
fouric
  • 1,809
  • 26
Check for the existence of the directory:
/lib/arm-linux-gnueabihf
the soft-float version do not have this directory, they have:
instead, or you can list the packages installed using:
dpkg -l
and see the platform in the third column (all/armhf/armel)
ikku
  • 4,494
    Since someone just misinterpreted this, to make it absolutely clear: If you have a /lib/arm-linux-gnueabihf, your system is hard-float. – goldilocks Mar 25 '15 at 16:16
24
The accepted answer is correct, but a really simple method is:
dpkg --print-architecture
If your system is using a hard float architecture, you will then see:
armhf
ARM Hard Float. :-)
Chris
  • 350
Issue the command:
readelf -A $(which dpkg)
On a hard-float (hf) system, you will see this as part of the output:
Tag_ABI_VFP_args: VFP registers
See http://www.cnx-software.com/2013/04/22/how-to-detect-if-an-arm-elf-binary-is-hard-float-armhf-or-soft-float-armel/
Will
  • 200
