When I remote access the raspberry pi with software now installed I do not get to access the current session displayed on my tv, but rather a new session.
Is there software to access the current running session so I can use the keyboard and mouse connected to my laptop to control my raspberry pi?
ATM I use putty and Xming to access my PI, but that creates a new user session instead of the active one.
Ghanima
  • 15,855
  • 119
Tom
  • 161
5 Answers5
You need to install x11vnc daemon on the linux distro with runs on Pi. Then run that command;
x11vnc -display :0 -usepw -noxdamage -ncache 10 -ncache_cr -listen IP_of_pi -allow allowed_ip_address
After ran the command, connect to pi with any VNC client.
Ghanima
  • 15,855
  • 119
gurcanozturk
  • 3,748
You need x11vnc. This will allow you to connect to the same session on the TV.
Alex Chamberlain
  • 15,530
  • 67
  • 113
nyitguy
  • 213
On my standard RPi I only need to run x11vnc without any parameters to be able to control the live session on the Pi with the TightVNC client on my Windows laptop. A couple of things did fool me for a while though, there must be a space between -display and the :0 bit, and if you've had an aborted session, you must either kill it on the Pi (eg vncserver kill :0) reboot it, or use a different display number. You also need to check the port that x11vnc is using, as displayed in the text after you run it. After a day of researching, it now works a treat.
You should install VNC.
Basically you need to follow the instructions here.
The basics are:
  1. Install tightvncserver: sudo apt-get install tightvncserver.
  2. Make a shell strict with the start command.
  3. Add an init script.
  4. Install the tightvnc viewer from the website.
  5. Connect up.
I might add more help later, if you need it.
hifkanotiks
  • 1,901
I was able to get a remote connection start after using a shortened version of the command that gurcanozturk shared.
After installing x11vnc, I edited
/etc/xdg/lxsession/LXDE/autostart
to run the following command:
This allows using VNC to connect once then you would need to reboot the device in order to make another connection.
To connect with VNC use the
IP_of_pi:5900
This should get you connected up and working.
Ghanima
  • 15,855
  • 119
