I now this is a long shot, but some reasons I was using Raspbian wheezy on Raspberry Pi 2, and I was able to use HC05 bluetooth module with wiringpi.
Lately I had switched it to Raspberry Pi 3, yet I still want to use same sd card and same code to work with HC05. However as far as I understand, Raspberry Pi 3 had some modifications to its serial configurations, therefore I am unable to use serial port anymore. The code that used to work returns error no 14 when I try serialOpen on wiringPi.
My question is, is it in anyway possible to use an old Raspbian Wheezy version with Raspberry Pi 3, but still enable the bluetooth module? Probably I am going to be the only one having this problem since wheezy is outdated and Raspberry Pi 3 is a quite recent model, but I will appreciate if you have any ideas on what to change to enable serial port again.
Note: I have followed the basic tutorials exactly and they worked fine with Pi 2, therefore I do not have any problem with my code.
ttyS0instead ofAMA0? What difference does that make? You're unlikely to get any answer to this question, and you might want to consider the XY problem. You're scheming on something you think will be an easy fix and closing your eyes to the fact it is probably not the best idea. You're also guessing wiringPi will now magically work on the Pi 3 because you use an older OS, which seems unlikely. – goldilocks May 23 '16 at 16:17
