34
I am trying to login to the raspberrypi as root user via winscp, but it only says "Access denied", same thing for trying to login directly as root on ssh.
I have tried loging in as pi and doing sudo passwd root, which results in the console output passwd: Password changed successfully, however I still can't login as root
Diogo Gomes
  • 121
d0min0r4bb1t
  • 443
    It is possible. But is it wise to allow remote root login? Most people are better off leaving remote root login disabled and using sudo, when required. A sensibly secure default has been chosen for a reason. – moo Jul 12 '21 at 18:57
  • Is a there a counterpart to sudo when you want to ftp? if not I have a valid reason to login as root from filezilla and use my favorite editor on my PC to edit any file on the bloody raspberry pi. I don't want to use the crap nano, emacs, vi, ...etc :) it's backwards. – Meryan Jan 26 '22 at 16:25
If you want to login as root using SSH or WinSCP you need to edit the config of SSHD, do this:
  • Login, and edit this file: sudo nano /etc/ssh/sshd_config
  • Find this line: PermitRootLogin without-password
  • Edit: PermitRootLogin yes
  • Close and save file
  • reboot or restart sshd service using: /etc/init.d/ssh restart
  • Set a root password if there isn't one already: sudo passwd root
Now you can login as root, but I recommend you using strong password or ssh-keys
MadAntrax
  • 921
    Note that if the PermitRootLogin line starts with a comment sign (#) you have to remove that sign! – gosuto Apr 27 '18 at 07:17
    I was helped the last line to set root password. Thanks. – Andrei Krasutski Aug 21 '18 at 07:12
  • Additionally check the ownership of the authorized_keys file. My /root/.ssh/authorized_keys was owned by the wrong user and I kept getting my key rejected on login. – Tim Mar 12 '24 at 06:52
  • I have tried this but still unable to transfer a file with Putty or WinSCP to a /home/pi/docker/homeAssistant/backups folder – Dave Mar 25 '24 at 10:10
You cannot login as root because Raspbian does not have a root password. See Raspbian root default password
Normally ssh does not allow root access because this is considered a security risk. You should be able to do everything you need using sudo (which is the normal Debian practice).
If you REALLY want ssh root access it can be enabled.
  • I'm very glad someone at least pointed out that this is a security risk. SSH as root is never a good idea (particularly when using password auth). – stevieb Sep 30 '16 at 14:24
  • so how can I transfer a backup file to a /Home folder if I cannot have permission to my own files! – Dave Mar 25 '24 at 10:19
You can login as normal user (belong sudoer group) then
 sudo su -
to switch to root
南山竹
  • 131
You can
sudo su
Then use passwd to change the password
Steve Robillard
  • 34,687
  • 103
  • 109
Alex
