What easiest way to turn off/shut down the raspberry pi 3 model b? Would it be easier to just pull out my power source plug or to click menu --> shutdown --> shutdown and pull the plug or does it just do the same thing?
Asked
Active
Viewed 5,220 times
Do not pull the plug until the OS has shutdown completely. If you do, you risk corrupting the SD card and then needing to reformat and re-install. You can power down from the menu, once the green activity light goes off permanently and your display is off, you can safely assume the OS is done powering down and you can pull the plug. If you fancy the command-line, there's a command (poweroff) that will blink the green light 10 times once it's safe to unplug the Pi.
tlhIngan
- 3,372
- 5
- 19
- 33
This sounds like a job for Win32DiskImager - to make sure there is a fresh, known good image copy of the SD card on hand. – SDsolar Jun 02 '17 at 17:42
sudo init 0- Runlevel zero means it is off. Always watch the lights to make sure it finishes flushing out any cached disk writes before turning off power to protect the file system. – SDsolar Mar 21 '18 at 23:00
