i just started using lirc on raspberry 3. with
sudo apt-get install lirc
i put on the rpi, i changed the entries in
modules
hardware.conf
config.txt
as stated in http://alexba.in/blog/2013/01/06/setting-up-lirc-on-the-raspberrypi/
but i dont get any in- and out-pins associated with lirc. these are my outputs:
uname -a
Linux raspberrypi 4.4.16-v7+ #899 SMP Thu Jul 28 12:40:33 BST 2016 armv7l GNU/Linux
cat /sys/kernel/debug/gpio
GPIOs 0-53, platform/3f200000.gpio, pinctrl-bcm2835:
GPIOs 100-101, platform/soc:virtgpio, brcmvirt-gpio, can sleep:
gpio-100 ( |? ) out hi
sudo dmesg | grep lirc
[3.662057] lirc_dev: IR Remote Control driver registered, major 245
[4.659023] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[5.618718] lirc_rpi: auto-detected active high receiver on GPIO pin 18
[5.619407] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[5.619411] lirc_rpi: driver registered!
- i thought, the standard config would do me in and out on GPIO17 and 18. instead of it i've got only a virtual pin.
- possible hint: i use a python-script on startup with GPIO-Usage (physical Buttons) - disabled on startup for now.
- how to get "real" connections for lirc?
lircbut I do know that using 3 year old tutorials written for an obsolete OS which predatessystemdandDevice Treeisn't going to work. Try some more research based on current OS. – Milliways Aug 15 '16 at 11:41
