As the title saying, I want to start on this.
sudo service (my service name) start.
Where do I write this script that can make service initially start? My service is "apache2" and "bluetooth". Otherwise, I currently have a problem on bluetooth keyboard can't get automatically connected after reboot or a wake-up.
Asked
Active
Viewed 295 times
jefferyear
- 193
- 3
- 9
2You don't mention what model Pi or OS/version you are running, but Raspbian will automatically start Apache and if you are using a PI3 with built in bluetooth it will also be started automatically on boot. – Steve Robillard Aug 18 '16 at 09:07
Sadly, I own pi-2. Are there any treatment to make it initially start? I have the other service spamassassin I want to make it initially start. Thanks. – jefferyear Aug 18 '16 at 09:12
1@jefferyear When you install apache via sudo apt-get install it automatically starts at boot. You need to undo whatever you have done to stop it starting at boot. – joan Aug 18 '16 at 10:08
Without knowing what OS and version you are running we can't really answer your question. – Steve Robillard Aug 18 '16 at 12:32
I use Raspbian. – jefferyear Aug 19 '16 at 00:24
This is the way I used to schedule on reboot to start my custom monitoring scripts.
Say I have written a whatsapp service that will trigger messages to my whatsapp number when ever I have asked my Raspberry to monitor some activities at home. There are better ways to doing when it comes to services like apache/mongod etc.
cron way of doing -
- sudo crontab -e (select the editor of your choice like nano/vi etc. This will be a one time option asked by Pi.)
- @reboot service apache2 restart
Hope this helps.
Varad A G
- 848
- 6
- 17
Thank your response so that I am able to refer to "cron" this schedule tool. I just install cron-apt to make automatically update. But, upgrade this command seems to be done by administrator. I refer some articles they suggest to do manually "apt-get upgrade" this command. I am not clearly knowing why it is to be manually. – jefferyear Aug 25 '16 at 06:38
As far as I know we will be using some stable versions of tools while building a project. Lets say for example when I am building an application I am using a particular version of a server(httpd). My current configurations would work fine at this point. During the subsequent release the tool vendor changes some thing and which would be a part of new release. So when we schedule some auto upgrades this might take us to trouble. Please accept the the answer you are convinced. Thank you. – Varad A G Aug 25 '16 at 09:33
