When connecting to the Pi by the serial console, I'd like to have the default TERM be xterm, rather than the current default of vt102:
pi@raspberrypi:~$ echo $TERM
vt102
pi@raspberrypi:~$ tty
/dev/ttyS0
I know I could add this to .bashrc, etc. - but I only want to change the current default, and to otherwise not impact other types of connections.
https://www.debian.org/releases/jessie/i386/ch05s03.html.en seems to indicate that I should be able to add TERM=xterm to the boot parameters - which are at /boot/cmdline.txt. As such, I tried updating the following:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
to:
dwc_otg.lpm_enable=0 console=serial0,115200 TERM=xterm console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
... and then rebooting, but with no change. Now, http://man7.org/linux/man-pages/man7/bootparam.7.html indicates that this may be a "(useless?) example" (for reasons I don't understand).
Now, I did find /lib/systemd/system/serial-getty@.service, which contains the following:
[Service]
ExecStart=-/sbin/agetty --keep-baud 115200,38400,9600 %I $TERM
... but I can't find where the default $TERM is being defined.
I did add the following here:
Environment=TERM=xterm
This is working - but it seems that I'm still missing part of the puzzle here, as to where this is defaulting to vt102, or why this can't be set in cmdline.txt.
(Other sources I've already referenced:)
TERM=vt102, but work withTERM=xterm. Look at how many bashrc and such files are checking forTERM=xtermvarious things... – ziesemer Aug 26 '16 at 20:21TERM=xterm(orxterm*with pattern matching). The question here is/was how to change the defaultTERMenvironment variable for serial console connections, not whether or not it is required (please). – ziesemer Aug 26 '16 at 21:15TERM=vt102(and not beingTERM=xterm. Once connected to the Pi, I can send itexport TERM=xtermto enable color support and other functionality. All this Q/A was intended for was how to have this properly set by default, respecting the considerations listed. – ziesemer Aug 27 '16 at 12:22
