My web"nozing" told me that the two (the Rpi1B 256 and 512) variants are virtually the same hardware spec-wise (with the exception of the amount of RAM ofc. and maybe the SMT/cirquit layout).
- Could I simply take out the SD card (running Raspbian wheezy) from the 256MB one and place it into the 512MB one (any snags to be expected)?
- What about the other way around (start with 512, cutting back to 256)?
I would expect the OS to be "smart" enough to "adapt" to the extra (or less) amount of RAM. But does it?
-o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/nullto avoid the warning -- then cross your fingers someone didn't attach their own pi under the front porch O_O – goldilocks Aug 25 '16 at 23:36The only thing that would impact the 256 vs. 512 MB models would be if you had a software stack configured to run at boot that required more memory than the former could provide -- which is easy enough to check.So only a possible issue when "dowgrading"? And how to check that? – woosting Aug 25 '16 at 23:54
