GPIO
I think it is not possible, but I've found the QEMU 2.7.0 callback that gets called when you do GPIO:
hw/gpio/pl061.c:pl061_write
where PL061 is the GPIO controller of -M versatilepb (edit: -M raspi2 was added in QEMU 2.6, see that instead) which is documented here.
This is the setup I'm using to test it out.
You could then monitor GPIO changes by printing to a file:
s->parent_obj->mmio[0].addr
which contains the MMIO base addresses, e.g. 0x101e7000 as in:
/sys/devices/platform/amba/101e7000.gpio/gpio/gpiochip480
and the offsets within each controller can be obtained with offset.
You could also compile with:
./configure --extra-cflags=-DDEBUG_PL061=1
which prints some interesting PL061 debug information.
The hw/arm/versatilepb.c QEMU file sets up 4 such controllers, each one capable of dealing with 8 pins
The MMIO address of those controllers is given by the .dts device tree file, which is generated with the Linux kernel build from versatile-pb.dts.
I'm not sure how the exported IDs (e.g. 480) are chosen for the pins by the Linux kernel.
Linux has in-tree support for the PL061 under drivers/gpio/gpio-pl061.c, which my test script accesses througg /sys/class/gpio.
LEDs
Add a printf at hw/misc/arm_sysctl.c:
static void arm_sysctl_write(void *opaque, hwaddr offset,
uint64_t val, unsigned size)
arm_sysctl_state *s = (arm_sysctl_state *)opaque;
switch (offset) {
case 0x08: /* LED */
printf("LED val = %llx\n", (unsigned long long)val);
The kernel driver is drivers/leds/leds-syscon.c.
