39
I have a project in mind that uses Raspberry Pi to develop a software. The final product will be modification of the Raspberry Pi circuit (get rid of any components that the project doesn't use) and add in some other circuits of mine. For the software parts, it will be running Raspbian OS with my application software.
Is it legal to do that? I don't mind giving back if I can make a profit.
techraf
  • 4,319
henry chan
  • 409
    I am not a lawyer and you don't mention where in the world you are, but the short answer is yes. – Steve Robillard Nov 30 '16 at 06:16
  • If you are looking to strip down some things, other possible options may be using the "RaspberryPi Zero" or the "RaspberryPi Computer Module". – dave k Nov 30 '16 at 19:11
  • You won't have much luck ordering custom boards or chips in small quantities, but you could like use a PiZero and build up from there, via HAT or GPIO. – Chris G. Williams Nov 30 '16 at 20:35
  • Just added an answer to that closely related question-- the newest little Xorcom PBX box runs off a Pi ( https://xorcom.com/product/small-business-ip-pbx/ ) – Doobeh Dec 01 '16 at 13:02
  • I just updated my answer. You can approach Element14 and they can build custom PCB for you. Other than that you will not get those chips on their own (for a few more years), unless you buy allot of PiZeros and desolder the chips and solder them on your own PCB. – Piotr Kula Dec 01 '16 at 13:58
  • Just as an example of a business selling RPis (albeit unmodified) as part of their product, look at Kano. Their homepage only mentions the RPi as part of a quote from a review and I don't recall their packaging drawing attention to the existence of the RPi either (although the manuals etc do). – Darren Dec 01 '16 at 16:44
    Thanks for the examples everyone but this is not a classified ads page for Rpi based products. Please -- no more. – goldilocks Dec 01 '16 at 17:04
The answer to the question if something is legal or not, depends on the interpretation of laws in a particular jurisdiction. This answer should not be treated as a legal advice. It is based on published information by the relevant party.
Raspberry Pi Foundation made a clear statement that answers your question in the Starting a business with a Raspberry Pi article:
If [ ] you’re making a product which requires a Raspberry Pi to run, we don’t ask you to buy special permission or licences from us to use it. All we ask is that you include the words “Powered by Raspberry Pi” somewhere on your packaging. If your business is successful, we’d be very grateful if you could consider donating a small portion of your profits to the Raspberry Pi Foundation – but that’s all, and if you choose not to do that, that’s fine too.
Regarding the use of the "Raspberry Pi" trademark / logo the guidelines are published on the Trademark Rules And Brand Guidelines page.
techraf
  • 4,319
  • Does the "if you choose not to do that, that's fine too" only apply to the donation of profits or also to the "we ask [...] that you include the words 'Powered by Raspberry Pi' somewhere on your packaing" statement? – Captain Man Nov 30 '16 at 22:47
    @cat no, it says "ask", which means not mandatory. And actually, stating it's powered by a RPI would open you up to royalty issues as per the Trademark Rules. You have zero obligation to mark it as such, and an incentive not to. – cde Dec 01 '16 at 05:47
    @cde, I don't see how the Foundation could enforce it, so I kind of agree with you, but when a brit says, "only ask of you", they don't actually ask. They order you... in a polite way. :) – Prof. Falken Dec 01 '16 at 09:31
    @cde: "Ask" is indeed not mandatory, but that's because it's not mandatory to use an R.Pi in the first place. You'd need a lawyer to check whether your right to use an R.Pi in your product is conditional on the request to include those words. (Or skip the lawyer and follow the guidelines) – MSalters Dec 01 '16 at 10:18
  • @cde That phrase modifies the portion before the conjunction. They're asking you to send a bit of money if you make money off their product. It doesn't modify the "Powered by RasPi" portion. – jfa Dec 01 '16 at 21:40
  • It does... it's in the same sentence. They ask one, for the label, and in a different sentence ask money if your product is successful. ..... @jfa – cde Dec 01 '16 at 22:14
  • @cde "If your business is successful, we’d be very grateful if you could consider donating a small portion of your profits to the Raspberry Pi Foundation – but that’s all, and if you choose not to do that, that’s fine too." – jfa Dec 04 '16 at 16:44
You can get Element14 to make custom Raspberry Pi's for you:
http://www.technewsworld.com/story/Element-14-to-Bake-Custom-Raspberry-Pis-82670.html
Unfortunately - For whatever reason (most probably exclusivity agreements with Element14) the 2835/2836 is not available for retail purchase. So purchasing that chip from any other channel except Element14 is impossible for now. These agreements tend to run out after 5 to 10 years and cannot be renegotiated as they then may break unfair trade laws in the EU and US.
If you are making your own circuit based on the Raspberry Pi then yes it is legal. Because the PCB schematics is open source (in a limited form) The problem is... you will not get BCM chips because the manufacturer (Element14) most likely has exclusivity on that chip. I tried and it's impossible (the only way they will be interested is if you buy 500k chips at once.. good luck because Google wanted that in the Chromecast and couldn't even get it)(and don't buy Alibaba based chips because they are fakes or factory back door chips that did not pass QA)
If you are going to be buying Pi boards and modifying them then you still need to credit Raspberry Pi foundation even if you remove the logo's and any traces of anything in any way because those boards have specific licenses on them that are provided by the foundation.
You can use Raspbian without permission from foundation because it is based on Debian. You need to read their license page and credit in the appropriate places. You can use any operating system that runs on ARMv7 as long as you adhere to their license policies. Raspbian just includes some "nice" stuff for education, etc,etc but the packages are available across Linux and BSD now. Plus Windows packages emerging slowly too.
--Edit March 2017
As of this month, the Raspberry Pi is the 3rd best selling computer of all time, selling more than 12.5 million boards in the last five years. That is pretty decent since PC and Mac have been selling computers for 30+ years and take 1st and 2nd place.
I personally don't see Element14 letting go of this gold mine easily.
Glorfindel
  • 620
Piotr Kula
  • 17,307
  • 104
  • First you state that the foundation "has an exclusivity on that chip" and then that you were offered to buy 500k chips at once. Which is it?? – DepressedDaniel Dec 01 '16 at 01:28
    Probably both. The foundation has exclusivity, and the foundation doesn't consider it worth their time to sell you the chip (as the exclusive source) unless you buy 500k lots. – Alan Shutko Dec 01 '16 at 01:58
    The foundation does not have exclusivity for broadcom BCM2835 or BCM2836 processors. These are general purpose ARM System-On-Chips and can be purchased by anyone for any reason. Broadcom has a large history of only dealing in volume with confidentiality and non-disclosure agreements *AND* they also deal with custom designs, but the BCM2835 and BCM2836 are *NOT* custom designed for Raspberry... – cde Dec 01 '16 at 05:53
  • I couldnt buy any. I wanted 10k - They didnt even want to talk to me. Who knows.. maybe because im a nobody but then again I can buy other chips from them in 100's no problem. So yea. Just talking from experience – Piotr Kula Dec 01 '16 at 09:28
  • @CDE they were not custom designed for Pi - But Pi is the sole purchaser of these chips now, Please... go and find a way to buy 100 of these from them direct... – Piotr Kula Dec 01 '16 at 09:30
  • @ppumkin Broadcom won't sell in low quantities to anyone. Not just these. Any of their chips. – cde Dec 01 '16 at 13:37
  • Sure.. then how come I cannot buy BCM2835 from FARNELL? Or Microchip? Or any other distibuter who buys in million units and resells to public for markup?? I can buy other Broadcom chips from wholesaler's - Please.. I want to buy some. Give me a link where I can buy them. I even found a guy who sells rare A6 chips but no BCM2835 available. Unless you can factually provide any more insight.. please do not reply anymore. – Piotr Kula Dec 01 '16 at 13:40
    @ppumkin, lol, that sounds shady imho. – aaa Dec 01 '16 at 20:05
    Because microchip is a semiconductor manufacturer and not a reseller. .... why would they be selling a competitors chips? And you know a guy selling Apple A6 chips? The department of Homeland Security would be interested. – cde Dec 01 '16 at 22:22
  • Don't believe everything you read on the internet. So getting BCM2835 is out of the question I take it. – Piotr Kula Dec 01 '16 at 22:30
