I added the following to /etc/rc.local
    cd /home/pi/Desktop
    exec ./start_picoin.sh
The script it executes is nothing more then a simple echo at the moment. I would like this script to be executed in a terminal that stays open after execution. How can I do that?
clankill3r
  • 202
You could use a very nice tool called tmux. I use it everyday and what it basically does is gives the end user to run multiple scripts in detached mode (background), however a user can log in to the Detached Session whenever s/he wants at any given time.
  • You can install it via:
    sudo apt update
    sudo apt install tmux
  • In your case you could write a the tmux trigger on boot into your rc.local file as follows:
    ## YOUR rc.local file
    #!/bin/sh -e
    # always good and safe to use the complete path
    /usr/bin/tmux new-session -d -s mySession
    # This statement is a life-saver, if ever your code crashes
    /usr/bin/tmux set-option -t mySession set-remain-on-exit on
    # Create a window where you wish to run a code
    /usr/bin/tmux new-window -d -n 'my work' -t mySession:1 'cd /home/pi/Desktop; exec ./start_picoin.sh'
     exit 0
  • Now since your /etc/rc.local file is triggered on boot under sudo rights, the next time you boot you can see your session mySession by typing:
    sudo tmux ls
  • Once you see the session has begun, all you have to do is attach the background session using:
    sudo tmux a
  • You will see an empty bash shell, in order to navigate to your running code press Ctrl + B+1
  • Once you see your code running well and want to leave the code running in the background you can simply click: Ctrl + B+D to detach it.
  • If you want to close the complete session you can just type:
    sudo tmux kill-session
Shan-Desai
  • 1,531
http://www.raspberry-projects.com/pi/pi-operating-systems/raspbian/auto-running-programs-gui
I am assuming you are using GUI rather than command line? Follow that guide above to launch lxterminal on start up. If you have a script called BootScript.sh in the /home/pi directory then in your autostart file you want to add:
@lxterminal -e "/home/pi/BootScript.sh"
your script will read something like this:
#!/bin/bash
echo Hello World!
$SHELL
The $SHELL part at the ends stops the terminal screen from closing. Make sure you give your script execution privileges using:
chmod -755 /home/pi/BootScript.sh
Ghanima
  • 15,855
  • 119
pfl
  • 341
This is not simple because Raspbian will not give you terminal on boot logged in by default.
First, you need to edit /etc/inittab to enable auto login in your preferred console.
Then I would suggest to add your script to ~/.bashrc and it will execute on login.
EDIT
I've just realized that you asked something else:
Answer is to use nohup before your call.
So, it would be nohup myscript.sh & and it will run after you logout.
10robinho
  • 706
