25
I am trying to run a package on my Raspberry Pi:
At the terminal, I typed in “sudo apt-get install picap” followed by enter.
I get it installed but cannot execute "picap-setup" – instead an error message follows:
pi@raspberrypi:~ $ picap-setup Traceback (most recent call last): File "", line 1, in ImportError: No module named RPi
Python-dev and Rpi.GPIO are installed on the Pi. I also updated the Pi with the latest version with sudo apt-get update and sudo apt-get dist-upgrade.
Picap comes from : https://www.bareconductive.com/make/setting-up-pi-cap-raspberry-pi/
I am thankful for any hints.
99centsdreams
  • 359
5 Answers5
31
First of all, repeat following process
sudo apt-get install python-pip
pip freeze | grep RPi
see what you get after this second command, If you get a valid module for RPi.GPIO or not. And then following if not installed.
For Python 2
sudo apt-get install python-dev python-rpi.gpio
or
pip install RPi.GPIO
For python3
sudo apt-get install python3-dev python3-rpi.gpio
and then ( for python 2 or python 3):
picap-setup
These all worked for me, Just you need to verify pip freeze | grep RPi. And one more thing sometimes some modules are not available for normal user only for root user. Make sure. I did all above using my pi user.
titusfx
  • 103
BetaDev
  • 421
    I would not use pip to install to system packages, either install from system package manager with apt or use virtualenv if you want to use pip. – crasic Dec 18 '17 at 17:13
  • Yeah thats correct, agreed – BetaDev Dec 18 '17 at 17:15
    For Python3 use sudo apt-get install python3-dev python3-rpi.gpio. – Diomidis Spinellis Sep 29 '19 at 15:49
  • @crasic Could you explain why or point me in the direction of an explanation for simpletons? Thanks. – Phill Healey Jan 25 '20 at 20:31
  • I get the following when trying to run picap-setup on my Raspberry Pi 4 with Python 3.7 in a virtualenv: File "<stdin>", line 2 print GPIO.RPI_INFO['TYPE'] ^ SyntaxError: Missing parentheses in call to 'print'. Did you mean print(GPIO.RPI_INFO['TYPE'])?. It seems like this doesn't work with Python 3 – lolsky Dec 02 '20 at 04:34
If Python RPi module is missing, one can install pip with all dependencies and then install the module using pip or go with the better approach and install the module alone:
sudo apt-get install python-rpi.gpio
for Python3 this one:
sudo apt-get install python3-rpi.gpio
dmnc
  • 161
  • Some appliances/JeOS doesn't support distro upgrade (like Volumio) and updating and installing a lot of dependencies can break the system, so this is another reason why to go low profile like that. – dmnc Mar 12 '19 at 11:46
For Windows
pip install python3-rpi.gpio
or
Greenonline
  • 2,740
  • 36
Dhiren Biren
  • 151
I had a similar issue with my Pi. Doing a simple pip install solved the issue.
if using pycharm on windows then it will work like this
  1. upgrade pip
    C:\Users\sandeep\PycharmProjects\newnum1\venv\Scripts\python.exe -m pip install --upgrade pip
  2. installing the module
  3. it worked for me should work for everyone
Jangir
