I have 4.8V 0.5A Light Bulb and want to use RPI's GPIO pins to power it. How can I do that?
Asked
Active
Viewed 927 times
This is an excellent question as a lot of people want to drive loads using their Raspberry Pi. I'm not sure why you received a -1 your question may have need rephrasing.
Yes, You can drive a load using a Bipolar transistor or a MOSFET. A MOSFET will be more efficient.
The MOSFET in the schematic above is a general purpose one. You will have to choose a Logic Level MOSFET that will work with 3.3V on the gate.
You can add isolation using an optocoupler as well if you want higher isolation between the power rails.
Chetan Bhargava
- 1,262
- 3
- 15
- 29
How can I do so?"
– Chetan Bhargava Jan 24 '17 at 03:45
