Following my previous question, I now have a working LCD display, but with a different issue.
The problem is the same as in this question, yet I am unable to find a solution.
I don't have a xorg.conf
file, but in xorg.conf.d/99-calibration.conf
I put the result of xinput_calibration
, which is:
Section "InputClass"
Identifier "calibration"
MatchProduct "ADS7846 Touchscreen"
Option "MinX" "61348"
Option "MaxX" "3095"
Option "MinY" "3738"
Option "MaxY" "62309"
Option "SwapXY" "1" # unless it was already set to 1
Option "InvertX" "1" # unless it was already set
Option "InvertY" "1" # unless it was already set
EndSection
xinput list
gives
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ ADS7846 Touchscreen id=6 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
xinput list-props 6
gives
Device 'ADS7846 Touchscreen':
Device Enabled (116): 1
Coordinate Transformation Matrix (117): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Calibration Matrix (246): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Calibration Matrix Default (247): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Send Events Modes Available (248): 1, 0
libinput Send Events Mode Enabled (249): 0, 0
libinput Send Events Mode Enabled Default (250): 0, 0
Device Node (251): "/dev/input/event0"
Device Product ID (252): 0, 0
libinput Horizontal Scroll Enabled (253): 0
and, as you can see, none of the options specified in 99-calibration.conf
is used.
If I try running, as suggested in the answers on the other question
xinput set-prop 6 "Evdev Axis Calibration" <Min-X> <Max-X> <Min-Y> <Max-Y>
xinput set-prop 6 "Evdev Axes Swap" 1
I get
property 'Evdev Axis Calibration' doesn't exist, you need to specify its type and format
property 'Evdev Axes Swap' doesn't exist, you need to specify its type and format
Any idea?
