I'm kind of new to raspberry pi, and I saw a tutorial about making a LED blink. The LED was connected to pin 17, but the tutorial said pin 11. I connected the LED to pin 17, and in the terminal I wrote pin 11 to HIGH, and it came on. Are the gpio pins addressed differently for software/hardware? Where can I get a chart of these correlations? Very confused. Please help
Asked
Active
Viewed 1,531 times
There are several different GPIO numbering schemes.
You need to ensure that the software you are using is using the numbering scheme you expect.
See https://pinout.xyz/ for the gory details.
The most popular numbering schemes are
- the (physical) expansion header pin number
- the (Broadcom) GPIO number
I use this chart.
GPIO pin pin GPIO
3V3 1 2 5V
0/2 (SDA) 3 4 5V
1/3 (SCL) 5 6 0V
4 7 8 14 (TXD)
0V 9 10 15 (RXD)
17 (ce1) 11 12 18 (ce0)
21/27 13 14 0V
22 15 16 23
3V3 17 18 24
10 (MOSI) 19 20 0V
9 (MISO) 21 22 25
11 (SCLK) 23 24 8 (CE0)
0V 25 26 7 (CE1)
0 (ID_SD) 27 28 1 (ID_SC)
5 29 30 0V
6 31 32 12
13 33 34 0V
19 (miso) 35 36 16 (ce2)
26 37 38 20 (mosi)
0V 39 40 21 (sclk)
If the GPIO column has a V it indicates the pin is connected to the power rail and not a GPIO.
Where 2 figures are shown separated by a / the first figure is the GPIO number used on the first revision Pi B boards.
joan
- 71,024
- 5
- 73
- 106
