I'm having some trouble understanding which drive identifiers are available at different stages of system boot.
I'm running a Pi 2B with a btrfs root mounted on an external USB SSD. I'd like to address the root fs by PARTUUID rather than kernel name descriptor in case USB storage plug order ever changes but I'm having a hard time getting bootup working.
I've built an initrd.img containing neccessary btrfs modules; bootup is fine using /dev/XdXn but PARTUUID naming fails every time and dumps me out into busybox. initrd.img is setup in config.txt using "initramfs initrd.img-4.9.24-v7+ followkernel".
Note: / is mounted on a subvolume of the btrfs volume named ROOT.
This boots:
root@Tree-Eater:/etc# cat /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=tty1 root=/dev/sda2 rootfstype=btrfs rootflags=subvol=ROOT elevator=deadline rootwait rootdelay=5 quiet splash plymouth.ignore-serial-consoles
This fails:
root@Tree-Eater:/etc# cat /boot/cmdline.uuid
dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=be046359-02 rootfstype=btrfs rootflags=subvol=ROOT elevator=deadline rootwait rootdelay=5 quiet splash plymouth.ignore-serial-consoles
Relevant fs & block device info below, any thoughts?
root@Tree-Eater:/etc# cat /etc/fstab
proc                    /proc           proc    defaults          0       0
/dev/mmcblk0p1          /boot           vfat    defaults          0       2
LABEL=external_btrfs    /               btrfs   defaults,space_cache,ssd,noatime,nodiratime,subvol=ROOT         0 0
LABEL=swappy            /swap           ext4    defaults,noatime,nodiratime                                     0 2
# btrfs fs root for snapshots
LABEL=external_btrfs    /mnt/btrfs      btrfs   defaults,noauto,space_cache,ssd,noatime,nodiratime              0 0
/dev/mmcblk0p2          /mnt/sdroot     ext4    defaults,noatime,nodiratime,noauto                              0 0
root@Tree-Eater:/etc# lsblk -f
NAME        FSTYPE LABEL          UUID                                 MOUNTPOINT
sda
├─sda2      btrfs  external_btrfs b21e0b28-05d1-4518-a4c9-77cacdf83d08 /mnt/btrfs
└─sda1      ext4   swappy         74ac5717-c894-4d16-97e2-78a07bb219e3 /swap
mmcblk0
├─mmcblk0p2 ext4                  2f840c69-cecb-4b10-87e4-01b9d28c231c /mnt/sdroot
└─mmcblk0p1 vfat   boot           2D2D-CD16                            /boot
root@Tree-Eater:/etc# blkid -o export
DEVNAME=/dev/mmcblk0p1
SEC_TYPE=msdos
LABEL=boot
UUID=2D2D-CD16
TYPE=vfat
PARTUUID=d660c869-01
DEVNAME=/dev/mmcblk0p2
UUID=2f840c69-cecb-4b10-87e4-01b9d28c231c
TYPE=ext4
PARTUUID=d660c869-02
DEVNAME=/dev/sda1
LABEL=swappy
UUID=74ac5717-c894-4d16-97e2-78a07bb219e3
TYPE=ext4
PARTUUID=be046359-01
DEVNAME=/dev/sda2
UUID=b21e0b28-05d1-4518-a4c9-77cacdf83d08
UUID_SUB=d2439418-1cc2-47d4-9e36-3598de7fb75b
TYPE=btrfs
PTUUID=d660c869
PTTYPE=dos
root@Tree-Eater:/etc# btrfs subvolume show /
        UUID:                   db80ba63-dc08-bc42-8f65-ce0caee0cae1
        Parent UUID:            -
        Received UUID:          -
        Creation time:          2017-05-22 00:09:26 -0700
        Subvolume ID:           257
        Generation:             4829
        Gen at creation:        6
        Parent ID:              5
        Top level ID:           5
        Flags:                  -
        Snapshot(s):
                                ROOT-2017-05-23_08:15
be046359-02– Milliways May 25 '17 at 02:36blkid -o exportshows all of the proper ids and labels for everything. – arglebargle May 25 '17 at 04:53
