Is there any unique identifier like the serial number (00000000xxxxxxxx), which is specific to an exact board? And which cannot be spoofed or cracked or changed? and can also be retrieved to identify the board type?
Thank you
Thank you
the only 2 identifiers which are more or less unqiue, I know about, are:
cat /sys/class/net/eth0/address or ifconfig eth0 | grep HWaddr | awk '{print $NF}'.
The result will be something like b8:27:eb:2e:6a:20The MAC address is only 48 bits and the serial number looks even less. So they are by no means cryptographically strong.
You could now generate a HMAC of these values, or maybe from both (by chaining).
You should consider that it is possible to disable the wlan0 interface (and probably the eth0 aswell). Which would void your MAC address result, so you need to test for that.
