38
I've not ordered mine (yet!), but I do some overclocking as a hobby to the extent that my netbook, Android phone, desktop, and even my wife's Blackberry are overclocked.
Is there potential to overclock the RPi beyond stock voltage and speeds?
I figure I can rig some sort of custom cooling if need be.
Kyle Macey
  • 2,103
  • 30
  • If my Pi won't boot when I overclock it, how do I come back to the previous state? Do I have to backup the whole SDCard at each step? Thanks. – Xavier Nodet Jul 26 '12 at 19:29
    @XavierNodet, maybe you should ask your own question? It will get more attention on here. – Kyle Macey Jul 26 '12 at 21:45
    Done, with answer... http://raspberrypi.stackexchange.com/questions/1338/easiest-way-to-return-to-a-known-good-state-when-overclocking – Xavier Nodet Jul 29 '12 at 18:07
5 Answers5
30
Without overvoltage (i.e. at the default 1.2V), most Pis can run at up to 800MHz stably.
With overvoltage, 1000MHz is common.
WARNING: Setting any of the parameters which over volt your Raspberry Pi will set a permanent bit within the SOC and your warranty is void. So If you care about the warranty do not adjust voltage.
References:
Jivings
  • 22,538
  • 90
  • 139
finnw
  • 5,790
  • 32
    I read your references and I don't see evidence that 1GHz is common with over voltage. – LovesTha Jun 12 '12 at 23:05
  • I have not seen that figure for overvolting before but it seems about right for overclocking. The raspberry pi foundation and distributors do support overclocking but not overvolting. – Shane Hudson Jun 13 '12 at 13:50
  • Sorry I cannot remember the forum thread where I read that figure, it's not the one I linked. – finnw Jun 13 '12 at 16:33
13
The Raspberry Pi contains a /boot/config.txt.
This file is read by the GPU before the ARM core is initialised. It can be used to set various system configuration parameters. Which can be used for overclocking.
WARNING: Setting any of the following parameters which over volt your Raspberry Pi will set a permanent bit within the SOC and your warranty is void. So If you care about the warranty do not adjust voltage.
|      Option          |                                                       |
| arm_freq             | frequency of ARM in MHz. Default 700.
| gpu_freq             | Sets core_freq, h264_freq, isp_freq, v3d_freq
|                      | together.
| core_freq            | frequency of GPU processor core in MHz. Default 250.
| h264_freq            | frequency of hardware video block in MHz. Default 250.
| isp_freq             | frequency of image sensor pipeline block in MHz.
|                      | Default is 250.
| v3d_freq             | frequency of 3D block in MHz. Default 250.
| sdram_freq           | frequency of SDRAM in MHz. Default 400.
| over_voltage         | ARM/GPU core voltage adjust. [-16,8] equates to
|                      | [0.8V,1.4V] with 0.025V steps. Default 0 (1.2V) [1]
| over_voltage_sdram   | Sets over_voltage_sdram_c, over_voltage_sdram_i,
                       | over_voltage_sdram_p together
| over_voltage_sdram_c | SDRAM controller voltage adjust. [-16,8] equates to
| over_voltage_sdram_i | SDRAM I/O voltage adjust. [-16,8] equates to
|                      | [0.8V,1.4V] with 0.025V steps. Default 0 (1.2V)[1]
| over_voltage_sdram_p | SDRAM phy voltage adjust. [-16,8] equates to
From the elinux wiki.
Jivings
  • 22,538
  • 90
  • 139
There are a list of confirmed clock speeds achieved which would save you some time: http://elinux.org/RPi_config.txt#Overclocking_options so someone has managed 1000MHz with some overvolting applied, of course this invalidates your warranty so maybe stock up on a few :)
EdChum
  • 1,548
I overclocked mine without touching the voltage for a long time:
arm_freq=940
gpu_freq=380
sdram_freq=530
overvoltage=0
I tested these values with quake and my rpi never crashed with this oc.
After trying it with voltage I got these values. They are "floored" because I didn't want to reboot everytime for every 10MHz.
arm_freq=1000
core_freq=500
sdram_freq=600
overvoltage=2
This might not run stable with quake3 but is rocksolid as Spigot (Minecraft) server.
It's a UK-built Model B from late 2013 (got it last christmas :D). Just to be more precise what hardware we are talking about.
ecth
  • 139
  • Maybe I should also add that I mainly use my old Dell Venue Pro's power supply with 5V and 1A :) – ecth Jun 22 '14 at 10:10
I am currently using:
arm_freq=1100
sdram_freq=600
overvoltage=12
core_freq=500
The highest temperature my CPU has ever reached is 61 degrees. However the overclocking capabilities change depending on the manufacturer and batch.
Matthew
  • 979
