I want a simple python script to run in background, therefore I configured daemon test.service in /etc/systemd/system/.
[Unit]
Description=Test service
After=multi-user.target
[Service]
Type=simple
ExecStart=/usr/bin/python /home/pi/daemon.py
Restart=on-abort
[Install]
WantedBy=multi-user.target
My executing script daemon.py toogles a LED controlled by a button.
#!/usr/bin/python
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
# Configure button pin
GPIO.setup(14, GPIO.IN, pull_up_down=GPIO.PUD_UP)
# Configure LED pin
GPIO.setup(18, GPIO.OUT)
def button1(channel):
print "Toogle LED!"
GPIO.output(18, not GPIO.input(18))
GPIO.add_event_detect(14, GPIO.FALLING, callback=button1, bouncetime=300)
try:
while True:
pass
finally:
print "cleanup() GPIOs"
GPIO.cleanup()
Now, I can start my script as a service with systemctl start test.service and stop it the same way. But for a clean script, I want to execute GPIO.cleanup() before the script is closed by systemctl stop test.service. How can I achieve that? The finally doesn't seem to work in this case...
Secondly, all the print messages like "Toogle LED!" cannot be seen when I call systemctl status test.service. Is the output written to another file somewhere else?
Thank you for your help in advance!
