How do I restart sshd on raspbian stretch?
This does not work:
pi@raspberrypi:~/.ssh $ sudo systemctl restart sshd
Failed to restart sshd.service: Unit sshd.service not found.
This does not work:
Same issue with both stretch and jessie. Until you enable the service with:
systemctl enable ssh
you cannot refer to the service as "sshd". Once the service is enabled, no problem, you can even disable the service with:
systemctl disable sshd
Really stupid in my opinion but that's the way it is.
ssh vs sshd thing is a deliberate decision by the folks who bring you systemd. LOL
– Seamus
Oct 11 '23 at 20:04
In my case on raspberry pi 3B+ device with raspbian OS work this:
sudo service ssh status
sudo service ssh restart
As stated in the comments the main service is ssh.service. But you can it also address with sshd.service. As you can see ssh.service has an Alias:
pi ~$ systemctl cat ssh
# /lib/systemd/system/ssh.service
[Install]
WantedBy=multi-user.target
Alias=sshd.service
pi ~$
Quoted from man systemd.unit:
In addition, unit files may specify aliases through the Alias= directive in the [Install] section; those aliases are only effective when the unit is enabled.
With
pi ~$ sudo systemctl enable ssh
You can also get it with:
pi ~$ systemctl status sshd
/usr/sbin/sshd -D. – Ingo Feb 12 '18 at 01:34
