I am having some troubles with pipon the Raspberry.
These are the information about the OS:
piName@raspberry ~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 7 (wheezy)"
NAME="Raspbian GNU/Linux"
VERSION_ID="7"
VERSION="7 (wheezy)"
ID=raspbian
ID_LIKE=debian
ANSI_COLOR="1;31"
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
piName@raspberry ~ $ uname -a
Linux piname 4.1.19+ #858 Tue Mar 15 15:52:03 GMT 2016 armv6l GNU/Linux
My Python version associated with pip is 2.7.3, although I have also Python3 installed.
First when I list the outdated pip packages I get the following warning (sorry for the verbosity):
pip list --outdate
DEPRECATION: The default format will switch to columns in the future.
You can use --format=(legacy|columns) (or define a format=(legacy|columns)
in your pip.conf under the [list] section) to disable this warning.
/usr/local/lib/python2.7/dist-packages/pip/_vendor/requests/packages
/urllib3/util/ssl_.py:318: SNIMissingWarning: An HTTPS request has been
made, but the SNI (Subject Name Indication) extension to TLS is not
available on this platform. This may cause the server to present an
incorrect TLS certificate, which can cause validation failures. You can
upgrade to a newer version of Python to solve this. For more information,
see https://urllib3.readthedocs.io/en/latest
/security.html#snimissingwarning.
SNIMissingWarning
/urllib3/util/ssl_.py:122: InsecurePlatformWarning: A true SSLContext object
is not available. This prevents urllib3 from configuring SSL appropriately
and may cause certain SSL connections to fail. You can upgrade to a newer
version of Python to solve this. For more information, see
/security.html#insecureplatformwarning.
Some packages can be upgraded, some others cannot. For example pip install --upgrade scipy gives errors and one of this is the following
Failed building wheel for scipy
Running setup.py clean for scipy
Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-pmGCTQ/scipy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" clean --all:
`setup.py clean` is not supported, use one of the following instead:
- `git clean -xdf` (cleans all files)
- `git clean -Xdf` (cleans all versioned files, doesn't touch
files that aren't checked into the git repo)
Add `--force` to your command to use it anyway if you must (unsupported)`enter code here`
Note that wheel is installed.
Also I have errors trying to upgrade numpy.
Does anyone know how to solve these issues?
scipy- if you use a current Raspbianpipwill install these. – Milliways Feb 28 '18 at 23:02Stretch– Milliways Mar 01 '18 at 22:52Wheezyif it works - but don't expect any support. There is no official upgrade path from Wheezy to Jessie/Stretch, although there are those who claim to have upgraded. Buy a new card, they are cheap enough, and you will need at least 8GB, preferably 16. – Milliways Mar 02 '18 at 03:44
