I created an application that I want to start on boot for the raspberry.
I had already set up a service for wvdial by hand to make it start on boot and it works like a charm so I then started working on this application of mine. It's no fancy stuff, it's a "simple" service with a command to start, I defined the working directory and the user that will run it.
[Unit]
Description=Blah Blah
[Service]
Type=simple
WorkingDirectory=/home/pi/appdir
ExecStart=/home/pi/appdir/the-script-to-start.py
Restart=always
RestartSec=60
User=pi
When booting, it's not started (systemd says it's inactive (dead)). No output about it on journalctl. If I then try starting by hand with systemctl, it works.
What am I missing?
PS1
Ok.... I think python (or the basic set up to get it working) is not to blame. I switched to configuring a very simple bash script that just prints a line and nothing else... so it goes out with exit code 0.
After rebooting:
● my-service.service - some Service
   Loaded: loaded (/etc/systemd/system/my-service.service; static; vendor preset: enabled)
   Active: inactive (dead)
When I run it manually:
   Active: activating (auto-restart) since Wed 2018-04-11 16:00:55 UTC; 2s ago
  Process: 744 ExecStart=/home/pi/blahblah/prueba.sh (code=exited, status=0/SUCCESS)
 Main PID: 744 (code=exited, status=0/SUCCESS)
Is there something I can do in systemd configuration so that I can see more debugging information about how it's working on boot?
PS2
After modifying LogLevel to debug and reboot, I can see that for wvdial, we have this info from journalctl about 22 seconds into boot process (for starters, there's more stuff ):
Apr 11 16:53:06 raspberrypi systemd[1]: wvdial.service: Trying to enqueue job wvdial.service/start/replace
Apr 11 16:53:06 raspberrypi systemd[1]: wvdial.service: Installed new job wvdial.service/start as 182
Apr 11 16:53:06 raspberrypi systemd[1]: wvdial.service: Enqueued job wvdial.service/start as 182
Apr 11 16:53:06 raspberrypi systemd[1]: wvdial.service: Passing 0 fds to service
Apr 11 16:53:06 raspberrypi systemd[1]: wvdial.service: About to execute: /usr/bin/wvdial
Apr 11 16:53:06 raspberrypi systemd[1]: wvdial.service: Forked /usr/bin/wvdial as 498
Apr 11 16:53:06 raspberrypi systemd[1]: wvdial.service: Changed dead -> running
Apr 11 16:53:06 raspberrypi systemd[1]: wvdial.service: Job wvdial.service/start finished, result=done
Apr 11 16:53:06 raspberrypi systemd[1]: Started wvdial service.
Apr 11 16:53:06 raspberrypi systemd[498]: wvdial.service: Executing: /usr/bin/wvdial
But no word about my service.
eftshift0
  • 750
[Unit] After=?
[Install] WantedBy=?
Or // does the script have the python shebang? is it +x? if both are set and still not working try to add the /usr/bin/python infront to the ExecStart // But i think its After=/Before= // WantedBy=
[Unit]
Description=Scanner Script Service
After=server.service multi-user.target
[Service]
Type=simple
WorkingDirectory=/opt/files/
ExecStart=/usr/bin/python /opt/files/scanner.py
Restart=always
[Install]
WantedBy=multi-user.target
(working, server.service is a selfmade too)
ghost
  • 86
  • Script does have shebang. It's also set with +x. Let me try adding the python binary to the call to see if that solves it. – eftshift0 Apr 11 '18 at 15:27
  • Ok.... I think python (or the basic set up to get it working) is not to blame. I switched to configuring a very simple bash script that just prints a line and nothing else... so it goes out with exit code 0. If I run it manually.... I'll add a comment.... I know that formatting does't work here – eftshift0 Apr 11 '18 at 15:58
Seems this is already solved, but wanted to add an alternative solution for starting a Python program (or any program for that matter) at boot time:
open crontab as follows:
crontab -e
the crontab will be opened in your chosen editor (default is nano)
Add a line to the end of your crontab file that looks like this:
@reboot /usr/bin/python3 /home/pi/any-program.py > /home/pi/cronjoblog 2>&1
Your program named any-program.py will execute during the boot sequence, and any issues will be recorded in the file cronjoblog
Seamus
  • 21,900
  • 70
  • Didn't know about this possibility. Nice touch! It's still more flexible with systemd because it's possible to stop/start at will but still nice to know. – eftshift0 Apr 14 '18 at 05:25
-1
Seems like adding the section [Install] and enabling the service, it starts working (I didn't have to do it with wvdial but....).
Thanks for your attention.
eftshift0
  • 750
  • No need to add this as new answer, this is what @ghost advised. Adding the [Install] section and running 'enable' is what sets the service to be started at boot time. – Mark Stosberg Apr 12 '18 at 13:35
