I am wanting to learn about the BIOS on a Raspberry Pi motherboard. What is the BIOS called? Does it have a specific name or is it just called a BIOS on a Raspberry Pi?
2BIOS stores some software to control your PC before it boots(example-setup hard drive, memory etc). The Pi does not use a "BIOS" like in a PC. It just initializes the Broadcom chip (CPU, Cache, GPU) using firmware written for that chip and passes straight to the Operating system. The OS then detects hardware and ram reported by Broadcom. This makes booting really fast but only Broadcom knows how to debug or "set" properties on the fly. – Piotr Kula Jul 18 '13 at 12:33
The firmware is closed-source proprietary code programmed into the SoC (System on a Chip) processor, which cannot be modified. Upon power-up the firmware will initiate a bootloader on the SD card. I do not believe that any other services are provided through the SoC firmware, so it is not really a "BIOS" (Basic Input/Output System) per se. After this point everything else comes from the SD card.
According to the software section of the wiki, the boot order is as follows:
- First stage bootloader - This is used to mount the FAT32 boot partition on the SD card so that the second stage bootloader can be accessed. It is programmed into the SoC itself during manufacture of the RPi and cannot be reprogrammed by a user.
- Second stage bootloader (bootcode.bin) - This is used to retrieve the GPU firmware from the SD card, program the firmware, then start the GPU.
- GPU firmware (start.elf) - Once loaded, this allows the GPU to start up the CPU. An additional file, fixup.dat, is used to configure the SDRAM partition between the GPU and the CPU. At this point, the CPU is release from reset and execution is transferred over.
- User code - This can be one of any number of binaries. By default, it is the Linux kernel (usually named kernel.img), but it can also be another bootloader (e.g. U-Boot), or a bare-bones application.
- 841
- 8
- 13
9I would only add that 1st stage bootloader is burned on small ROM inside of SoC. As mentioned, it's only responsibility is loading
bootcode.bin
from SD card. This is the reason why it is impossible to boot RaspberryPi from medium other than SD card. – Krzysztof Adamski Jul 17 '13 at 18:38 -
@TevoD is almost right in what he wrote in his answer - RaspberryPi is using closed source firmware binary as a bootloader. The current version can be found here. The two files that makes the firmware are bootcode.bin
(2nd stage bootloader) and start.elf
(GPU "firmware"). What is interesting and quite unique to RaspberryPi is that it starts from GPU
(graphics chip) and this is where bootloader actually runs. GPU
then starts ARM CPU
and runs Linux kernel.
After Linux is started, code on GPU
is not unloaded, however. Instead it runs it's own simple OS, called VCOS
(Video Core Operating System
). Linux kernel communicates with its services using special mailbox protocol
and using interrupts (GPU can produce ARM interrupts). You can read some information about mailbox protocol used for framebuffer
here. GPU is responsible not only for graphic things - it also controls clocks and produces audio, for example. In this regard, GPU firmware can be considered something similar to BIOS
from normal PC computers. You can find more information on this reading RaspberryPi Linux kernel drivers.
You can also find some more information in this answer.
- 9,615
- 37
- 53
Good point. I was considering the BIOS question to be explicitly referring to onboard firmware, not the SD Card, and added the boot order for a more complete answer. Yours certainly takes it on from there. +1 – Tevo D Jul 17 '13 at 17:51
