Is there a list anywhere of the keyboard shortcuts in Raspbian? There's nothing obvious in the documentation that I've found. I've established that Cmd+r opens starts 'run' and Cmd+e opens an explorer window. Are there any others?
Asked
Active
Viewed 3.8k times
Assuming that you are using LXDE, the default desktop, you are actually runnig openbox as the window manager.
grep -A 1 \<keybind /etc/xdg/openbox/rc.xml will give you the default ones.
~/.config/openbox/rc.xml contains your shortcuts if it exists.
M Noit
- 926
- 5
- 7
1With
Linux raspberrypi 3.18.11-v7+the file is:/home/pi/.config/openbox/lxde-pi-rc.xml– AjayKumarBasuthkar May 15 '16 at 12:48 -
echo "grep -A 1 \<keybind /etc/xdg/openbox/rc.xml" > ShowShortcuts.................... then do:. ShowShortcuts– Andrew Oct 23 '17 at 05:08 -
A useful answer, thanks. It's important to remember that
C,S,AandWin the keyboard shortcuts means the Control, Shift, Alt and Windows (meta) keys. Also, adding a space and| lessto theechostring in @Andrew 's command would make it easier to read and work when the script file is opened in a new terminal. – Edward Nov 22 '17 at 21:19 -
Before finding this, I was using terminal with the
xdotoolcommand. The tool simulates keyboard/mouse activity and changes windows using the X11 window system. I know that on Raspbian GNU/Linux, there are some general shortcuts like F10, Control+Tab, Control+Alt+F1-F8 but I hadn't found the LXDE desktop window manager (openbox) ones. – Edward Nov 22 '17 at 21:37 -
(longer) code to create executable script file that opens in terminal:
echo -e '#\!/bin/bash\n# C-ontrol,S-hift,A-lt,W-indows\n# Show Raspbian LXDE desktop keyboard shortcuts (openbox window manager).\n# From a command found on the page <https://raspberrypi.stackexchange.com/questions/9344/raspbian-keyboard-shortcuts>.\ngrep -A 1 \<keybind /etc/xdg/openbox/rc.xml | less' > ~/show_desktop_key_shortcuts.sh; chmod +x ~/show_desktop_key_shortcuts.sh– Edward Nov 22 '17 at 22:53
The configuration file is the lxde-pi-rc.xml that contains different keybind keys. Just add one that you want in this file following the examples.
I found the lxde-pi-rc.xml but in my case it was in a different path: /etc/xdg/openbox/lxde-pi-rc.xml
I guess that in the recent versions they changed the path.
I hope it can help you.
Roberto Salgado
- 11
Alt+Spaceshows the window options menu which has all the useful commands. Remember to pressAlt+F11, which doesn't appear to be listed in the openbox (window manager) options file (see answer below). – Edward Nov 22 '17 at 22:04
