When issues arise using cron to schedule events, a frequently-heard explanation is that cron runs with a different set of environment variables than a "normal" user (e.g. pi). That's all well and good, but what is the environment for the cron user? If one is to avoid errors due to an incorrect environment when using cron, it would be useful to know what that environment is.
- 21,900
- 3
- 33
- 70
We can ask cron to tell us what its environment is.
- Create a shell script in your home directory (
~/) as follows (or with the editor of your choice):
$ nano ~/envtst.sh
- Enter/C+P the following in the editor:
#!/bin/sh
echo "env report follows for user "$USER >> /home/pi/envtst.sh.out
env >> /home/pi/envtst.sh.out
echo "env report for user "$USER" concluded" >> /home/pi/envtst.sh.out
echo " " >> /home/pi/envtst.sh.out
- Save the file and exit the editor; then set the file permissions as executable, and open your
crontabfor editing:
$ chmod a+rx ~/envtst.sh
$ crontab -e
- Enter the following line at the bottom of your
crontab:
* * * * * /home/pi/envtst.sh >> /home/pi/envtst.sh.err 2>&1
- Save and exit your
crontab. Usetailto view the output & (hopefully) observe the environment forcron. If there's nothing in the file after a minute, view the file~/envtst.sh.errfor error messages, and adjust as required. (NOTE: If you want to clear all prior error messages after troubleshooting:$ > ~/envtst.sh.err)
crontab: installing new crontab
$ tail -f ~/envtst.sh.out
HOME=/home/pi
LOGNAME=pi
PATH=/usr/bin:/bin
LANG=en_GB.UTF-8
SHELL=/bin/sh
PWD=/home/pi
env report for user concluded
This will repeat every minute, so enter ^C to stop the tail listing, edit your crontab again to "comment out" (or delete) the line just added. Save and exit the editor.
Note in the
tailoutput above thatcronhas a rather sparse environment; only six (6) variables are used to define it. Note thePATHconsists of only two directories. This is why your crontab entry fails if, for example, you're trying to launch a Python script that resides in your home directory. Note also that the user name (aka LOGNAME iaw System V) isn'tcron- it'spi!If you're not familiar, with your own user environment, it's useful to compare it against the
cronenvironment. We'll use the same shell script to add that to the "output" file~/envtst.sh.out:
$ ~/envtst.sh
- To view the output, open
~/envtst.sh.outin your editor, orcat ~/envtst.sh.outto see it in your terminal. It will likely be a fairly extensive output; 30 lines of text, more or less. Note in particular the following lines (assuming you've run this as userpi) :
USER=pi
HOME=/home/pi
LOGNAME=pi
_=/home/pi/envtst.sh
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
SHELL=/bin/bash
- You'll notice numerous differences in the two environments. This will help create rational
cronjobs, and help troubleshooting when they don't behave as you'd like.
- 21,900
- 3
- 33
- 70
$USERvariable isn't set -- seeenv report for user concluded. – Mark Smith Mar 26 '19 at 07:22cronenvironment, it's not that it's not set... it's just not used in the version ofcronon Raspbian (and Debian I think). Here's some more on that, and still more, and more. Likely more to this story, but I don't think $USER defined forcronin any Raspbian distro – Seamus Mar 26 '19 at 14:17env report for user concluded. Yeah... :) I stuck that in the script to emphasize that $USER isn't defined :P – Seamus Mar 26 '19 at 14:21
