Q How can I make iw wlan0 set power_save off permanent for stretch? What's the proper way to do it?
Edit I'm using an r-Pi 1 Mod. B with an Edimax wifi dongle and Raspian stretch.
I did it by simply adding a line to /etc/rc.local
/sbin/iwconfig wlan0 power off
Add that ahead of
exit 0
and it will run at every boot.
Power save mode was an issue years ago on older versions of Raspbian. But it is fixed for a long time. Now it is disabled by default with the WiFi driver brcmfmac. You will find it if you grep the journal for the driver:
rpi ~$ journalctl | grep brcmfmac:
Apr 14 22:13:28 raspberrypi kernel: brcmfmac: F1 signature read @0x18000000=0x15264345
Apr 14 22:13:28 raspberrypi kernel: brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43455-sdio.bin for chip 0x004345(17221) rev 0x000006
Apr 14 22:13:28 raspberrypi kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
Apr 14 22:13:28 raspberrypi kernel: brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 9.10.105 Compiler: 1.29.4 ClmImport: 1.36.3 Creation: 2018-03-09 18:56:28
Apr 17 09:01:27 raspberrypi kernel: brcmfmac: power management disabled
As you see, it is power management disabled. So there is no need to worry about it. You don't need to disable it again.
Update after getting information about used hardware:
If you do not have an on-board WiFi and using an USB/WiFi dongle then you will not find brcmfmac because there is another driver loaded for the dongle. To execute programs on boot up you can use a systemd Unit file. I will give you here a bit more comfortable example for switching off or on power_save. Create a Unit file with:
rpi ~$ sudo systemctl --full --force edit wifi_powersave@.service
[Unit]
Description=Set WiFi power save %i
After=sys-subsystem-net-devices-wlan0.device
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/sbin/iw dev wlan0 set power_save %i
[Install]
WantedBy=sys-subsystem-net-devices-wlan0.device
Now enable just what you want on boot up:
rpi ~$ sudo systemctl disable wifi_powersave@off.service
rpi ~$ sudo systemctl enable wifi_powersave@on.service
# or
rpi ~$ sudo systemctl disable wifi_powersave@on.service
rpi ~$ sudo systemctl enable wifi_powersave@off.service
journalctl | grep brcmfmac doesn't report anything, but iw wlan0 get power_save reports Power save: on. I'm using a Edimax Wifi dongle.
– participant
Apr 18 '19 at 16:29
rpi ~$ sudo systemctl enable|disable wifi_powersave@off.service sufficient, because the default behavior is power save on?
– participant
Apr 23 '19 at 21:01
%i with off and sudo systemctl enable wifi_powersave.service.
– Ingo
Apr 24 '19 at 09:49
@$WLANDEV instead of @STATE (/sbin/iw dev %i set power_save off) just in case there are multiple Wifi devices.
– Samveen
Sep 05 '20 at 11:51
powersave disabled on operating system Raspbian to powersave enabled on the Raspberry Pi OS.
– Ingo
Jun 21 '21 at 08:43
brcmfmac shows power save enabled on the journalctl - we must remember that Raspi isn't just the hardware, it depends on which flavor people are using ;) So while that could be truth for latest (or other versions of) Raspberry Pi OS, it may not be for others.
– João Ciocca
Mar 17 '23 at 23:08
This is still relevant for me when I want to use the RPi headless and log in through SSH, as there are no input devices plugged in and power management kicks in too early. Sometimes I couldn't log in via SSH, because the interface was already down. To permanently turn off WiFi power management, edit "/etc/network/interfaces" and add:
allow-hotplug wlan0
wireless-power off
# For second WiFi device, e.g. via USB
#allow-hotplug wlan1
# wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
#wireless-power off
cat the file, the configuration was still there... but I was back on having trouble until I sudo iwconfig wlan0 power off it.
– João Ciocca
Mar 17 '23 at 23:15
