Alternatively, you can create a mini-service which restarts the wlan0, making sure it starts at boot before hostapd and isc-dhcp-server.
Create the new script /etc/init.d/wlan0-restart
sudo vi /etc/init.d/wlan0-restart
with the following content:
#!/bin/sh
### BEGIN INIT INFO
# Provides: wlan0-restart
# Required-Start: $network
# Required-Stop: $network
# Should-Start:
# Should-Stop:
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Restarts wlan0 interface
# Description: Restarts wlan0 interface to fix problem with static address in WiFi AP
# X-Start-Before: hostapd isc-dhcp-server
### END INIT INFO
PATH=/sbin:/usr/sbin:$PATH
do_start() {
ifdown wlan0
ifup wlan0
case "$1" in
start)
do_start
restart|reload|force-reload)
echo "Error: argument '$1' not supported" >&2
exit 3
stop)
status)
echo "Usage: $0 start|stop" >&2
exit 3
esac
exit 0
Then execute the following commands:
sudo chmod 755 /etc/init.d/wlan0-restart
sudo update-rc.d –f hostapd remove
sudo update-rc.d –f isc-dhcp-server remove
sudo update-rc.d wlan0-restart defaults
sudo update-rc.d hostapd defaults
sudo update-rc.d isc-dhcp-server defaults
Reboot and check that wlan0 has its static IP address and that isc-dhcpd-server is running:
pi@raspberrypi:~$ ifconfig wlan0
wlan0 Link encap:Ethernet HWaddr e8:de:27:07:92:6a
inet addr:192.168.10.1 Bcast:192.168.10.255 Mask:255.255.255.0
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
pi@raspberrypi:~$ pgrep -l dhcpd
2315 dhcpd
ifup wlan0just after boot. If it works, then addauto wlan0in /etc/network/interfaces. – M Noit Sep 21 '13 at 11:40auto wlan0to the top of the /etc/network/interfaces file to no avail. – Justin Niessner Sep 21 '13 at 20:23
