I've been trying to setup a IR transmitter for ages. I'm running a RasPi B with the latest Raspbian lite.
I installed lirc and added dtoverlay=lirc-rpi,gpio_out_pin=23,gpio_in_pin=22,gpio_in_pull=up,debug=1 to my config.txt.
I really don't care about the receiver, I only need to be able to transmit signals.
If I try to irsend I get a hardware does not support sending error.
Here is the dump from the lirc service status. I've been trying to solve the error but with no luck.
May 26 00:48:39 raspberrypi lircd[578]: lircd-0.9.4c[578]: Warning: Failed to initialize hardware
May 26 00:48:39 raspberrypi lircd[578]: lircd-0.9.4c[578]: Notice: accepted new client on /var/run/lirc/lircd
May 26 00:48:39 raspberrypi lircd-0.9.4c[578]: Notice: lircd(default) ready, using /var/run/lirc/lircd
May 26 00:48:39 raspberrypi lircd-0.9.4c[578]: Info: Cannot configure the rc device for /dev/lirc0
May 26 00:48:39 raspberrypi lircd-0.9.4c[578]: Error: could not get file information for /dev/lirc0
May 26 00:48:39 raspberrypi lircd-0.9.4c[578]: default_init(): No such file or directory
May 26 00:48:39 raspberrypi lircd-0.9.4c[578]: Warning: Failed to initialize hardware
May 26 00:48:39 raspberrypi lircd-0.9.4c[578]: Notice: accepted new client on /var/run/lirc/lircd
