I don't have a HDMI screen, nor do I have access to the router.
From what Ive been told, it has Kali installed. I am connecting the Raspb directly to the computer with a Ethernet cable.
I have tried using advanced IP scanner without getting any results.
How do I find the IP of this thing so I can SSH into it?
  • 42,107
  • 85
  • 197
Hakaari
    I am assuming the network card on your computer can detect that its a direct connection and perform the cross over automatically? Other wise you need a cross over cable. Also what type of OS for the computer? you could try ssh pi@raspberrypi.local but not sure if your situation works with that. – Chad G Jun 17 '19 at 22:38
  • See https://raspberrypi.stackexchange.com/a/90866/8697 Of course, if it is directly connected the computer will have a networking tool which will tell you. – Milliways Jun 17 '19 at 23:44
    it has Kali installed ... what is it? – jsotola Jun 18 '19 at 00:39
  • @Chad G: Ive tried the pi@raspberrypi.local but no connection was opened., I am running windows 10. Ive tried finding out if my card allows direct connection or not, but I am unable to find any info about it, I have a "Killer E2400" card. – Hakaari Jun 18 '19 at 05:25
  • @ChadG Please note that a cross over cable is never an issue for "decades" because nearly all devices can detect it, also a Raspberry Pi. Mention it may only confuse newbies. – Ingo Jun 18 '19 at 08:31
  • @Ingo Thanks for making me feel old..../s – Chad G Jun 18 '19 at 15:37
  • @ChadG Sorry, I wounldn't be impolite :) It is this medium ... – Ingo Jun 18 '19 at 16:02
  • Are you sure that the Raspberry Pi 3B+ has an IP address? Since you are direct connecting to a laptop, one approach is to run Wireshark on the lap top and view all traffic. Power on the Pi and you should see either a DHCP request (the IP will be in the DHCP response) or an ARP announce message coming from the Pi that contains the IP address the Pi is using. – Chad Farmer Jun 20 '19 at 20:19
Since all RPi use b8:27:eb as the first three octets of their MAC address, you can use arp from your Mac/Linux PC, but you'll need to refresh the arp cache first. Here's a bash script that will do the job. You can get more details from my github page on the subject.
#!/bin/sh
: ${1?"Usage: $0 ip subnet to scan. eg '192.168.1.'"}
subnet=$1
for addr in `seq 0 1 255 `; do
( ping -c 3 -t 5 $subnet$addr > /dev/null ) &
done
arp -a | grep b8:27:eb
Save this as a file on your Mac/Linux (or any machine that runs bash), make it executable, and then run it from your command line.
EDIT dtd 20200104:
As "The Foundation" has changed its organizational structure, a new OUI will be used on Raspberry Pi 4B models. Therefore, the original answer (above) must be updated to cover the latest model RPi. This change affects the last line of the bash script above. Make the following change:
TO:
arp -a |grep -E --ignore-case 'b8:27:eb|dc:a6:32'
EXPLANATION:
Prior to the release of Raspberry Pi 4B, all RPi's used the OUI b8:27:eb as the first 3 octets of its MAC address. Beginning with Raspberry Pi 4B, a different organization is responsible for production, and the new OUI is: dc:a6:32. If the OUI of the MAC address of a device on the network matches one of these values, this tells us that one of the Raspberry Pi organizations have most likely made the hardware, and so it is most likely a Raspberry Pi device; the other possibility is that a device on the network is MAC spoofing!
Seamus
  • 21,900
  • 70
You can use a few different tools like nmap and other mapping tools.
But i would reccomend to use angry ip scanner as it's very simple to use.
dnorhoj
