13
In English, many adjectives support the -er ending to express a notion of exceeding:
  1. John is taller than Mary (is).
  2. Mary is smarter than John (is).
Of course, you can also have the more analytic construction:
  • Mary is more intelligent than John (is).
But with the notion of "does not exceed", less, only the analytic form is available:
  • John is less smart than Mary is.
  • John is less intelligent than Mary is.
Does any language express the less form using bound morphology the way we do with -er in (1) and (2)?
Alex B.
  • 8,744
Alexis Wellwood
  • 1,966
A diminutive is not the same as what a "less" morpheme would be — it lacks comparative semantics.
However, to answer your question, the answer is, no there is not any such language which expresses a concept of "less" synthetically, at least none has been found despite a very large (300+ language) cross-linguistic survey by Jonathan Bobalijk. See his paper "Universals in Comparative Morphology", for his explanation of why such a morpheme never occurs.
Alenanno
  • 9,388
  • 48
  • 80
    In case you were referring to my answer: I know exactly what the difference is between the two; fearing that there was no answer, I provided some information that might be interesting for the OP, though of course it is not the same thing. – Cerberus Feb 07 '12 at 06:10
    By the way, I excluded the languages I knew or could check (french, spanish, german) then asked around to native speakers of: Russian, Ungarian, Lithuanian, Swedish. But nothing came out. :) – Alenanno Feb 07 '12 at 10:16
    So what does this paper have to say about Turkish -cE, I wonder? – Mark Beadles Feb 07 '12 at 22:49
    ...and the answer is: Turkish was one of the languages surveyed and no "less" comparative was found; in fact, it says Turkish only has analytic degrees of comparison. – Mark Beadles Feb 07 '12 at 23:04
    To my knowledge, Bobalijk is pretty good about acknowledging counterexamples to his claims (including problematic data from Basque and Russian for his analysis of regular comparatives). So, I would need to see a paper analyzing the -cE as a less comparative, to be convinced. –  Feb 07 '12 at 23:29
In Turkish, the suffic "-cE" gives this meaning when added to adjectives, such as "güzelce". It means that the person or thing is less beautiful than the mentioned thing. For instance:
Annesi gibi güzelce bir kız
It means that she is less beautiful than her mother. However, in some contexts it can mean "nearly". I asked which meaning people think of when they hear words to which this suffix was added; they answered "less". However, this research is not very broad or scientific; I have only asked the people I could contact. Maybe this answer will help you to some extent.
I have found a paper about this suffix; however, the section related to it is very little and not very much detailed.
  • Please give a citation for this analysis of -cE? –  Feb 10 '12 at 04:37
  • @Knitter, as I mentioned before, I do not have a scientific research, I have asked only the native speakers when I am suspect of this meaning as a native speaker. I will try to find a research about this topic, when I find, I will share it. – Serpil Karabüklü Feb 10 '12 at 09:11
  • @Knitter, I cannot find a detailed research for the suffix; however, I find a little section in a paper for this meaning of the suffix. The language of the research is Turkish, so I have translated the related section. – Serpil Karabüklü Feb 18 '12 at 10:49
  • The translation is: "the meaning of less": The suffix gives the meaning of less to the root. Initially, the meaning seems as "like,as"; however, in depth it is "less". Being an adjective or an adverb changes the meaning of the word. "topluca kız" [: the girl who is less fat], "topluca katıldık." [:we attended (the missind object) as a unity.], "fazlaca para". The link of the paper is http://web.ebscohost.com/ehost/detail?vid=8&hid=24&sid=7837d888-4a3b-49a2-935c-dccdbad2b786%40sessionmgr13&bdata=JnNpdGU9ZWhvc3QtbGl2ZQ%3d%3d#db=uvt&AN=130555 – Serpil Karabüklü Feb 18 '12 at 11:09
Well, Krivoshein de Canese and Acosta Alcaraz' (2007:102) "Gramática Guarani" gives as "comparativo the inferioridad" ('inferiority comparative') the affix -ive, which attaches to the standard of comparison NP. Their example is "Susana omba'apo'ive Anagui" meaning 'Susana works less than Ana'. However, -i is a diminutive, and -ve is the comparative of superiority so... it seems that the meaning of inferiority is obtained compositionally from the superiority comparative...
user3355
  • 41
I don't know any language that does exactly what you want; but it may interest you to know that the diminutive suffix -lus can be used with adjectives in Latin:
(1) aedes = room, house
(2) aedicula = little room or house
(1) acer = petulant
(2) acriculus = a little/bit petulant
What's behind this is that the distinction between nouns and adjectives was not felt to be very strict in Latin: acer can mean "petulant" or "a petulant person/thing". But the diminutive form can certainly be used when the word is used adjectivally/attributively, as in vir acriculus.
Note that this suffix is productive, but it is relatively uncommon—certainly less common than English forms with "less".
Derived suffixes that work the same way are -ulus, -culus, -(u)sculus, -(u)nculus, -illus, -ellus. They can all indicate a diminutive or a repeated action (as in credulus).
Alenanno
  • 9,388
  • 48
  • 80
Cerberus
  • 7,976
  • 49
