I am trying to set up multiple I2C interfaces on my pi.
I have added the following lines to my /boot/config.txt and rebooted:
dtoverlay=i2c-gpio,bus=4,i2c_gpio_delay_us=1,i2c_gpio_sda=29,i2c_gpio_scl=31
dtoverlay=i2c-gpio,bus=3,i2c_gpio_delay_us=1,i2c_gpio_sda=35,i2c_gpio_scl=37
I have pull up resistors, and one i2c device wired to each of those pairs of pins with corresponding SDA/SCL. However, running i2cdetect -l shows this:
i2c-3 i2c i2c@3 I2CAdapter
Have I done something wrong? I have i2c-dev enabled via modprobe, and I have also enabled the I2C interface via raspi-config. Is there something else I need to do?
EDIT: Note, the i2c-3 bus shows up empty.
Tmello225
  • 97
  • Are you using a compute module? Standard Pis only have GPIO 0-27. – joan Sep 30 '19 at 15:14
  • @joan I don't think so, but pinout.xyz has the GPIO pins going 1-40 – Tmello225 Sep 30 '19 at 15:32
  • @joan According to the Rpi website, the 3B+ comes standard with a 40 pin gpio header. Is there something special I have to do to use dtoverlay with those extra pins? – Tmello225 Sep 30 '19 at 15:38
    Looks like you're using the physical pin numbers. You need to use the BCM numbers as they are listed on the pinout website – Dirk Sep 30 '19 at 16:16
  • @Dirk THAT WORKED! If you would like to add it as an answer I'll mark it as correct! – Tmello225 Sep 30 '19 at 16:25
All RPF documentation, settings and software (such as dtoverlay, gpiozero, etc) work with the BCM numbers. You can find these at pinout and elsewhere.
Dirk
  • 3,541
How to set up multiple I2C buses on Rpi3B+ and Rpi4B?
Answer
I often read forum discussions on setting I2C buses. I tried all for my Rpi3B+'s but all failed, perhaps my drivers or Rpi stretch was to updated. The guys saying it is OK never specified their os version or driver used.
I tried again for Rpi4B and found that I could use at least 2 buses very stable, 3 buses more or less stable, depending on length of connecting wires.
i2cdetect shows 5 busses, but only first 4 working, but not stable.
To do - I read that a new buster sep26 version is more stable (2019 june versions were bad.)
This is a summary of the config proved working. More details in Appendix A below
dtoverlay=i2c1,pins_2_3 (board pins 3, 5)
dtoverlay=i2c3,pins_4_5 (board pins 7, 29)
dtoverlay=i2c4,pins_6_7 (board pins 31, 26)
dtoverlay=i2c5,pins_12_13 (board pins 32, 33)
dtoverlay=i2c6,pins_22_23 (board pins 15, 16)
pi@raspberrypi:~ $ ls /dev/i2c*
/dev/i2c-1 /dev/i2c-3 /dev/i2c-4 /dev/i2c-5 /dev/i2c-6
Appendices
Appendix A - Rpi4V raspbian 10 buster Python 3.7.3 Multiple I2C Channel Testing Notes
# fi2c62.py  tlfong01 2019aug28hkt1433
from time import sleep import smbus import fprint53 as fprint import ftime53 as ftime
I2c Bus Setup Notes
pi@raspberrypi:~ $ date Wed 28 Aug 2019 03:26:24 PM HKT
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.58-v7l+ #1245 SMP Fri Jul 12 17:31:45 BST 2019 armv7l GNU/Linux
pi@raspberrypi:~ $ sudo nano /boot/config.txt
*** I2c Bus Config ***
i2cBus1 = smbus.SMBus(1) i2cBus3 = smbus.SMBus(3) i2cBus4 = smbus.SMBus(4) i2cBus5 = smbus.SMBus(5)
i2cBusDict = {'I2cBus1': i2cBus1, 'I2cBus3': i2cBus3, 'I2cBus4': i2cBus4, 'I2cBus5': i2cBus5, }
*** Pca9685 I2c Slave Device Congif ***
pca9685DevAddrDict = { 'Dev0': 0x40, 'Dev1': 0x41, 'Dev2': 0x42, 'Dev3': 0x43, 'Dev4': 0x44, 'Dev5': 0x45, 'Dev6': 0x46, 'Dev7': 0x47, }
pca9685RegAddrDict = { 'Mode1': 0x00, 'Mode2': 0x01, }
pca9685DataByteDict = { 'Mode1Reset': 0x11,
*** Read Write Print Device/Register Functions ***
def writeDevTwoBytes(i2cBus, devAddr, writeByte1, writeByte2): i2cBus.write_byte_data(devAddr, writeByte1, writeByte2) return
def writeRegOneByte(i2cBus, devAddrDict, devName, regAddrDict, regName, writeByte): devAddr = devAddrDict[devName] regAddr = regAddrDict[regName] writeDevTwoBytes(i2cBus, devAddr, regAddr, writeByte) return
def readDevOneByte(i2cBus, devAddr, readByteAddr): readByte = i2cBus.read_byte_data(devAddr, readByteAddr) return readByte
def readRegOneByte(i2cBus, devAddrDict, devName, regAddrDict, regName): devAddr = devAddrDict[devName] regAddr = regAddrDict[regName] readByte = i2cBus.read_byte_data(devAddr, regAddr) return readByte
def printRegOneByte(i2cBus, devAddrDict, devName, regAddrDict, regName): readByte = readRegOneByte(i2cBusName, devAddrDict, devName, regAddrDict, regName) print(printTitle, hex(readByte)) return
*** Main Test Function ***
def testWriteReadPca9685Bus1Dev0RegMode1():
fprint.printBeginExecFunction()
i2cBusName = 'I2cBus1'
devName    = 'Dev0'
regName    = 'Mode1'
#i2cBus      = fi2c.i2cBusDict[i2cBusName]
i2cBus      = i2cBusDict[i2cBusName]
devAddrDict = pca9685DevAddrDict
regAddrDict = pca9685RegAddrDict
writeByte = 0x77
readByte = readRegOneByte(i2cBus, devAddrDict, devName, regAddrDict, regName)
if readByte == writeByte:
    resultsString = 'Good'
else:
    resultsString = 'Bad'
fprint.printTitleOneByteNum('PCA9685 I2C Address',             fprint.indentFormat640, devAddr)
fprint.printTitleOneByteNum('PCA9685 MODE1 Register Written',  fprint.indentFormat640, writeByte)
fprint.printTitleOneByteNum('PCA9685 MODE1 Register Read',     fprint.indentFormat640, readByte)
fprint.printTitleString('Write/Read Results',                  fprint.indentFormat640, resultsString)
fprint.printEndExecFunction()
return
def testPingPca9685Bus1Dev0RegMode1():
devName    = 'Dev0'
regName    = 'Mode1'
compareByte = pca9685DataByteDict['Mode1Reset']
if readByte == compareByte:
else:
fprint.printTitleString('PCA9685 I2C Address',             fprint.indentFormat640, hex(devAddr))
fprint.printTitleString('PCA9685 MODE1 Register Written',  fprint.indentFormat640, hex(compareByte))
fprint.printTitleString('PCA9685 MODE1 Register Read',     fprint.indentFormat640, hex(readByte))
fprint.printTitleString('Ping Results',                    fprint.indentFormat640, resultsString)
return
*** Main Tests ***
def mainTests(): #ftime.testPrintDateTime() testPingPca9685Bus1Dev0RegMode1() testWriteReadPca9685Bus1Dev0RegMode1() return
*** Init/Main Functions ***
*** Init Function ***
def init(): pass return
#*** Main Function ***
def main(): init() mainTests()
return
*** Main ***
if name == 'main': main()
*** End of Program ***
End of answer
