I cannot get gstreamer on raspbian (buster) to play through a
usb-audio device, despite other players (vlc, aplay) being able to do
so. but i need gstreamer because of its API access, for mpd
players
like gmpc
this post is related to many others i've found (listed below), but i've exhausted the resources mentioned there, so i and want to report on experiments i've done, still without success.
Following suggestions here i find:
lsusb
Bus 001 Device 005: ID 0781:558c SanDisk Corp. Bus 001 Device 004: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
aplay -l
**** List of PLAYBACK Hardware Devices **** card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA] Subdevices: 7/7 Subdevice #0: subdevice #0 Subdevice #1: subdevice #1 Subdevice #2: subdevice #2 Subdevice #3: subdevice #3 Subdevice #4: subdevice #4 Subdevice #5: subdevice #5 Subdevice #6: subdevice #6 card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI] Subdevices: 1/1 Subdevice #0: subdevice #0 card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1] Subdevices: 1/1 Subdevice #0: subdevice #0 card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio] Subdevices: 1/1 Subdevice #0: subdevice #0
cat /proc/asound/modules
0 snd_bcm2835 1 snd_usb_audio
cat /proc/asound/cards
0 [ALSA ]: bcm2835_alsa - bcm2835 ALSA bcm2835 ALSA 1 [Device ]: USB-Audio - USB PnP Sound Device USB PnP Sound Device at usb-3f980000.usb-1.2, full speed
and so i've editted my /usr/share/alsa/alsa.conf
to look like:
defaults.ctl.card 1 # 0
defaults.pcm.card 1 # 0
The image below captures my understanding of the various alternative paths from sound files to audio output.
(i see mentions of pulseaudio around others; does it impact gstreamer? should i include it in the picture?)
i've tried 7 different experiments, and also varied touchscreen vs. HDMI display options. Result summary:
the vlc
experiments show that it is able to get to usb-audio in both
cases. aplay
with the touchscreen is also able to send sound to
usb-audio. (my current guess is that aplay is missing some mp3
codec
and barfing out noise?)
clearly there are lower-level (kernel? raspbian?) resource paths that
i don't know about. how can i make gstreamer consume whatever
resource it is that vlc
and `aplay are able to use to get to usb-audio?
