I want to add 4 INMP441 digital MEMS microphones to the GPIO pins of Raspberry pi 4 to perform sound source localisation.
Here's a reference link to the mic: https://robu.in/product/inmp441-mems-high-precision-omnidirectional-microphone-module-i2s/?gclid=CjwKCAiAioifBhAXEiwApzCztoUeo5VuBrtSFQYbl6_9TnM_MW8JvmZ6-p_USflxKZf5BR87sbBx8hoCw7gQAvD_BwE
Questions in particular:
  1. The mics have a pin named WS. What does it do & where to connect that?
  2. I have to record 4 individual audios. So, should I connect all the SDAs together or connect them seperately? Same question for SCLs
  3. The mics also have L/R selectors, Should I make them L & R according to the placement or can I keep them all in one mode?
    They use I2S which is NOT compatible with I2C. – joan Feb 08 '23 at 08:24
  • This might help: https://raspberrypi.stackexchange.com/questions/140455/how-can-rpi-pico-w-control-a-gpio-pin-connected-i2c-digital-mems-microphone/140465#140465 – tlfong01 Feb 08 '23 at 08:52
This is not an answer to your question, but you may find some of the information helpful in your research:
There are at least 264 Q&As here re I2S. Start with that, and narrow the list. For example, here are two: 1, 2.
Wrt the RPi4 hardware in particular, see the BCM2711 ARM Peripherals documentation; Chap 7. Please do a bit of research first, and then edit your question.
Seamus
  • 21,900
  • 70
