What libraries are available for interfacing with the GPIO?
not a complete list, but here are a few - although I think this question will be closed, as list-type questions tend not to work well on the stack sites, as there will be a never-ending stream of answers – user2813274 Jun 22 '15 at 04:05
I'm going to interpret what I think you might be asking more broadly as "How can I control GPIO from userland?"
A very nice way to get started using GPIO is using the /sys filesytem. You can do it all from the command line.
For example,
cd sys/class/gpio
echo 0 > export
cd gpio0
echo high > direction
More documentation is in linux/Documentation/gpio.txt.
- 2,004
- 2
- 15
- 18
- 374
- 6
1Are there any tutorials that use this method? I have only seen libraries (mainly the python one). – Shane Hudson Jun 13 '12 at 13:56
1The other answers for this question are much better - this answer does not answer the question about libraries. – recantha Jan 02 '13 at 13:29
There is one that I've found here. I haven't had the chance to test it, as my Pi hasn't arrived. It does, however, look assuring. There's even a forum thread here that professes promising payoff. If you want a down-to-the-basics C example using standard libraries, there's one here from eLinux.
- 1,614
- 17
- 22
RPi.GPIO is a Python package for GPIO control.
This tutorial video shows the basic usage of the package.
- 2,004
- 2
- 15
- 18
- 4,048
- 4
- 29
- 31
I realize I'm answering a question that is years old, but there is one that hasn't been mentioned yet: gpiozero. https://gpiozero.readthedocs.io/en/stable/
It should already be installed on new versions of Raspbian. You can also install it on other versions of Linux. https://gpiozero.readthedocs.io/en/stable/installing.html
- 242
- 3
- 10
quick2wire can be used by regular users (not root):
Quick2Wire Python API
A Python library for controlling the hardware attached to the Raspberry Pi's header pins, without running as the root user.
While this link may answer the question, it is better to include the essential parts of the answer here and provide the link for reference. Link-only answers can become invalid if the linked page changes. – Mark Booth Feb 07 '13 at 00:59
@MarkBooth : "the essential part of the answer" is "can be used by regular users" unlike other answers. – dugres Feb 07 '13 at 14:51
Johny-Five is quite easy to use for those familiar with Node.js or JavaScript. See http://johnny-five.io/examples/raspi-io/
npm install johnny-five raspi-io
var five = require("johnny-five");
var Raspi = require("raspi-io").RaspiIO;
var board = new five.Board({
io: new Raspi()
board.on("ready", function() {
var led = new five.Led("P1-13");
led.blink();
Specially useful for Pi projects controlling GPIO through a Web server
- 131
- 6
It is really simple to control the GPIO ports in any language as shown on http://elinux.org, so I believe that you actually do not need a framework for the direct control.
You need to know which additional features you expect of a framework, like
- Remote control via a browser
- A pretty browser UI or maybe a standalone program
- Automatic timebased control (cron jobs)
I ended up writing a framework for myself: Control GPIO ports over HTTP and with cron jobs which perfectly fits my needs. I wanted to have something for home-automation. So I needed cron jobs and a JSON web interface to run a native app on my iPhone. Therefore I did not write a browser UI. I believe it would also be good for an alarm system.
I did not find a (complete) list of frameworks yet. There are some mentioned on the forum of raspberrypi.org.
- 2,004
- 2
- 15
- 18
- 119
- 2
Pi4J allows you to control the GPIO pins using Java. I'm not sure how it works but there's an explanation at http://pi4j.com/
- 979
- 3
- 10
- 20
