I am attaching a mic to my Raspberry Pi 2 Model B (Jessie) and using it for my PocketSphinx implementation.
I see this in the system:
$cat /proc/asound/cards
0 [ALSA           ]: bcm2835 - bcm2835 ALSA
                     bcm2835 ALSA
1 [Mic            ]: USB-Audio - Samson Meteor Mic
                     Samson Technologies Samson Meteor Mic at usb-3f980000.usb-1.2, full speed
According to PocketSphinx documentation, I need to move the mic to index 0. In Wheezy, you alter the file located at /etc/modprobe.d/alsa-base.conf with the following:
options snd-usb-audio index=0
However, in Jessie, the ALSA configuration system has changed. There is no alsa-base.conf anymore and it is replaced by /usr/share/alsa/alsa.conf.
The format in the new conf file doesn't seem to be compatible with the old format.
Help!
colinwong
  • 171
I found a workaround. Instead of re-ordering the index for the mic card, I can change the default mic card with this:
$sudo vi ~/.asoundrc
pcm.usb
    type hw
    card Mic
pcm.internal
    type hw
    card ALSA
pcm.!default
    type asym
    playback.pcm
        type plug
        slave.pcm "internal"
    capture.pcm
        type plug
        slave.pcm "usb"
ctl.!default
    type asym
    playback.pcm
        type plug
    capture.pcm
        type plug
        slave.pcm "usb"
Make sure to change "Mic" to whatever card name is recognized by your system by doing "cat /proc/asound/cards".
colinwong
  • 171
  • I got the following error: ALSA lib dlmisc.c:252:(snd1_dlobj_cache_get) Cannot open shared library /usr/lib/arm-linux-gnueabihf/alsa-lib/libasound_module_ctl_asym.so – Rafi Aug 15 '16 at 15:34
