I am attempting to setup a Plantronics .Audio 400 DSP with a Raspberry Pi 2 Model B as the default device with Jessie installed. Headset Link: http://www.plantronics.com/us/product/audio-400-dsp
So far in all attempts I have been unsuccessful in setting this up as the default device. The USB is recognized by the Pi, and manually selecting this via aplay or arecord work:
aplay test.wav –Dsysdefault:CARD=DSP
arecord test.wav –Dsysdefault:CARD=DSP
Below I will include some research I have done and what I attempted:
In short, does anyone have detailed instructions on how to connect a USB Headset (microphone + headphones) to a Raspberry Pi 2 with Jessie installed as the default device?
Thanks!
user40580
  • 81
  • Been trying to do the same thing with the same headphones. The program PulseAudio Volume Control helps to set various options for input and output of sound devices. But I have yet to get the microphone to work on the headset. Sorry this isn't too helpful. – energyi Feb 05 '16 at 23:52
    Try this? http://superuser.com/a/1045885/20881 – Leif Gruenwoldt Feb 26 '16 at 18:21
Have you been trying to create and use an ~/.asoundrc file? I have not been using USB-speakers or microphones yet but set my Bluetooth speakers and microphones as system-defaults via this file.
Create the file ~/.asoundrc with the following content:
pcm.!default {
    type hw
    card 1
ctl.!default {
    type hw
    card 1
Explanation: USB sound cards are registered as card 1 on Raspbian Jessie. (see: Best way to setup USB mic as system default on Raspbian Jessie)
If this does not help I provide you my working bluetooth-config, maybe you are able to translate it according to your USB-device-properties:
pcm.!default {
        type plug
        slave {
                pcm {
                        type bluealsa
                        device <MAC>
                        profile "a2dp"
        hint {
                show on
                description "Calisto"
ctl.!default {
        type bluealsa
EDIT: It seems that you also have to edit your alsa-base.conf file. Have look at: Unable to set default input and output audio device on Raspberry jessie
Stefan Wegener
  • 297
From your first link, change your default cards to 1, and also delete the hashtag on the line that says, load card-specific configuration files (on request). Then go into and edit /lib/modprobe.d/aliases.conf and change the line, options snd-usb-audio index=-2, to, options snd-usb-audio index=0, then run, cat /proc/asound/cards, and check to see that your device is at 0.
References: - https://superuser.com/questions/989385/alsa-base-conf-missing-in-new-raspberry-pi-raspbian-jesse - http://cmusphinx.sourceforge.net/wiki/raspberrypi
liamvovk
