I’m trying to control an IR HVAC unit in my house with a Raspberry Pi 2 and an infrared shield (see here: http://bit.ly/29iC0lr).
I followed the instructions on the IR shield product page with tips from a few other places and receiving signals from the HVAC remote works great. I was able to create a .conf file and irsend sees the buttons I configured when I use the LIST command but when I try SEND_ONCE, I get this response:
irsend: hardware does not support sending
I spent several hours trying various OSes (including piCore 6.1-v7 and Raspbian Jesse 2016-05-27 and 2015-11-21) and two versions of LIRC (0.9.0 and 0.9.4) but always got the same result.
I confirmed that the IR LED is working using a digital camera and a python script that manually operates the GPIO pin.
Can anyone point me in the right direction to troubleshoot this? Is there any way to find out why LIRC seems to think my hardware doesn’t have a transmitter?
Thanks in advance.
Note: my /boot/config.txt includes this line for lirc-rpi
dtoverlay=lirc-rpi,gpio_in_pin=18,gpio_out_pin=17
[EDIT 7-7-2016]
Here's some additional info, including the output from several commands in the Troubleshooting section on this page: http://aron.ws/projects/lirc_rpi/
The output of cat /sys/kernel/debug/gpio does not look right but I don't know what to do about it. :-\
I have the following line in /etc/rc.local:
modprobe lirc_rpi gpio_in_pin=18 gpio_out_pins=17
I also tried a similar bit of code in /etc/modules but it didn't make any difference.
pi@raspberrypi:~ $ ls -l /dev/lirc*
crw-rw---- 1 root video 244, 0 Jul 7 11:27 /dev/lirc0
lrwxrwxrwx 1 root root 21 Jul 7 11:27 /dev/lircd -> ../var/run/lirc/lircd
pi@raspberrypi:~ $ dmesg | grep lirc
[ 5.219904] lirc_dev: IR Remote Control driver registered, major 244
[ 5.230067] lirc_rpi: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.196796] lirc_rpi: auto-detected active low receiver on GPIO pin 18
[ 6.197243] lirc_rpi lirc_rpi: lirc_dev: driver lirc_rpi registered at minor = 0
[ 6.197248] lirc_rpi: driver registered!
pi@raspberrypi:~ $ sudo cat /sys/kernel/debug/gpio
GPIOs 0-53, platform/3f200000.gpio, pinctrl-bcm2835:
gpio-35 (? ) in hi
gpio-47 (? ) out lo
pi@raspberrypi:~ $ cat /proc/interrupts
CPU0 CPU1 CPU2 CPU3
16: 0 0 0 0 ARMCTRL 16 Edge bcm2708_fb dma
20: 1500 0 0 0 ARMCTRL 20 Edge DMA IRQ
32: 145314 0 0 0 ARMCTRL 32 Edge dwc_otg, dwc_otg_pcd, dwc_otg_hcd:usb1
49: 0 0 0 0 ARMCTRL 49 Edge 3f200000.gpio:bank0
50: 0 0 0 0 ARMCTRL 50 Edge 3f200000.gpio:bank1
65: 26 0 0 0 ARMCTRL 65 Edge 3f00b880.mailbox
66: 2 0 0 0 ARMCTRL 66 Edge VCHIQ doorbell
75: 1 0 0 0 ARMCTRL 75 Edge
77: 120 0 0 0 ARMCTRL 77 Edge DMA IRQ
82: 192 0 0 0 ARMCTRL 82 Edge mmc0
83: 5 0 0 0 ARMCTRL 83 Edge uart-pl011
96: 0 0 0 0 ARMCTRL 96 Edge arch_timer
97: 3798 2724 1275 1139 ARMCTRL 97 Edge arch_timer
FIQ: usb_fiq
IPI0: 0 0 0 0 CPU wakeup interrupts
IPI1: 0 0 0 0 Timer broadcast interrupts
IPI2: 2225 2478 3697 2901 Rescheduling interrupts
IPI3: 7 6 8 9 Function call interrupts
IPI4: 3 5 0 1 Single function call interrupts
IPI5: 0 0 0 0 CPU stop interrupts
IPI6: 0 0 0 0 IRQ work interrupts
IPI7: 0 0 0 0 completion interrupts
pi@raspberrypi:~ $ lsmod
Module Size Used by
cfg80211 419759 0
rfkill 16659 2 cfg80211
8192cu 528485 0
evdev 10226 1
snd_bcm2835 19739 0
bcm2835_gpiomem 3023 0
snd_pcm 74833 1 snd_bcm2835
snd_timer 18164 1 snd_pcm
lirc_rpi 6638 0
snd 52116 3 snd_bcm2835,snd_timer,snd_pcm
lirc_dev 8169 1 lirc_rpi
rc_core 16910 1 lirc_dev
uio_pdrv_genirq 2966 0
uio 8228 1 uio_pdrv_genirq
ipv6 341892 30
/boot/config.txt? – joan Jul 06 '16 at 12:54Just change this script to use the output pin (17), run it and point a digital camera or your cell phone camera at the LED. You should see a faint white light blinking in the center of the LED.
– gq9000 Dec 04 '16 at 13:35
